SteveCanbury Posted 12 hours ago Share Posted 12 hours ago I began working for a new company recently, and I'm working on a Custom Layout Template for them. I chose to put my information boxes running horizontally along the bottom (in a similar fashion to Rene Rabbitt's Layouts). I was told this is incorrect, and that it is a "standard" to have all page info along the right side running vertically (or treating the right side as the bottom). Can anyone tell me if this is a True Industry "Standard" ? Or if people just prefer to do it that way. Link to comment Share on other sites More sharing options...
Doug_N Posted 11 hours ago Share Posted 11 hours ago Depending on the size of the drawing sheet, having the title boxes on the right side of the drawing running vertically allows the most drawing area. It seems to be an informal norm for most architectural, structural, mechanical, and electrical drawings. Just my experience anyway. Link to comment Share on other sites More sharing options...
JKEdmo Posted 11 hours ago Share Posted 11 hours ago 20 minutes ago, Doug_N said: Depending on the size of the drawing sheet, having the title boxes on the right side of the drawing running vertically allows the most drawing area. It seems to be an informal norm for most architectural, structural, mechanical, and electrical drawings. Just my experience anyway. I would agree. It's most common to have titleblocks on the right side vertically. If the set is rolled, it means you do not have to unroll the roll to see all the plan set information. Also, using a vertical strip for info means you are left with a more square drawing area on the sheet than if you did a horizontal title block. Those are two advantages I can think of. Link to comment Share on other sites More sharing options...
joey_martin Posted 11 hours ago Share Posted 11 hours ago I have been working in the industry since the late 80's early 90's, right side vertically is the standard. When rolled, you should be able to find all relevant information from the title block without needing to unroll. 3 Link to comment Share on other sites More sharing options...
SteveCanbury Posted 10 hours ago Author Share Posted 10 hours ago Thank You all for the responses Link to comment Share on other sites More sharing options...
jorgearaya Posted 9 hours ago Share Posted 9 hours ago United States National CAD Standard - V6 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted 6 hours ago Share Posted 6 hours ago i see more and more where it is on the right, but it is readable without having to tilt your head (shift Joey's text 90 degrees). Its more readbale, but the text also tends to be wrapped more which ironically makes it less readable Link to comment Share on other sites More sharing options...
SteveCanbury Posted 6 hours ago Author Share Posted 6 hours ago 3 hours ago, jorgearaya said: United States National CAD Standard - V6 Thank You Jorge Link to comment Share on other sites More sharing options...
Renerabbitt Posted 1 hour ago Share Posted 1 hour ago (edited) FYI my templates come pre-packaged with 6 different title block styles in various sheet sizes and include different color washes for the first page Non traditional title blocks still have an information block at the rightmost roll-edge(To the negative reaction. Not sure why I earned that, my name was used to describe a layout style that does go against the typical standard, and I have many different styles, of which are designed and offered up here for free for reference... show some love, same team!) Edited 50 minutes ago by Renerabbitt 1 Link to comment Share on other sites More sharing options...
