dishwasher added to cabinet now offset in X17
SHCanada2
FWIW, in X17 a Dishwasher doesn't insert into a cabinet.  It is placed instead of a cabinet and the countertop generates on top of it..That way the Dishwasher is placed correctly in the plan view.
But any existing plans brought into X17 at this time will need to be fixed.
Ah! I see
2 hours ago, Steve_Nyhof said:
Not working for me
Steve, You don't even need to regen the 2D.  All you need to do is edit the y offset of the bounding box to 0.
The other option is to just delete the cabinet and place the dishwasher from the library.  X17 symbols work correctly when placed that way.  You will have a countertop above the dishwasher - or you can create a custom countertop over all the cabinets and the dishwasher.
The other option is to just delete the cabinet qnd place the dishwasher from the library.  X17 symbols work correctly when placed that way.  You will have a countertop above the dishwasher - or you can create a custom countertop over all the cabinets and the dishwasher.
I'll test it out. I have groupings of kitchen cabinets, one if of a sink and DW and some cabinets, so I will need to fix it up and save it back to the library. Thank you!
1 hour ago, Steve_Nyhof said:
All fixed up and back in the library. Now I hope they don't change something that messes it up :huh:
:lol::wub:
BTW,  You really should modify those Cabinet grouping (Architectural Blocks) so that the Dishwashers are not inserted into a cabinet.  X17 treats DWs as being installed between cabinets vs in a cabinet - just like they ar installed/built in a kitchen.
How do you get the countertop to appear over the dishwasher?  I don't see anything in the DBX that gives that option.  Do you have to extend the countertop from the next cabinet?
Sure don't remember this from the X17 changes that were discussed as Beta testers.
The new dishwashers in X17 are designed to be free standing.  If you place one next to a base cabinet, or in between two of them, the program should automatically extend the counter top over it.  If you are using an old one that is designed to go into a cabinet, I don't think it will work.
Offset should be 0
Bounding Box y should also be 0
However, I find that placing a Dishwasher or Trash Compactor or a Wine Refrigerator on a wall at 45 degrees is pretty much impossible.  I will investigate further and report my findings to Chief.  I suspect it's a problem with any angle other than 0 and 90.
X17 has many new options for symbols.  For DW's, TC's, and similar appliances the following can be used:
  • Appliances (built-in base cabinets)
  • Appliances (under wall cabinets)
  • Appliances (undercounter)
If you have any such items in a "Place Library Object" toolbar button you can find the object in your library and edit the Options to make it function properly.  Most - if not all Core, Bonus and Manufacturer Library objects will already have those properly set.
You should however check the User Library Objects.  Rene - take note ^_^
"built-in base cabinets" and "under wall cabinets" have been in the program for a very long time.  I can't tell for sure but I don't think any thing has really changed with these settings (other than the bug that Jason posted about). Hopefully they get that fixed quickly so that we don't need to fix up all of our old plans when we bring them into X17.
The "undercounter" appliance is new so I don't think this will affect any existing user libraries.  It looks like all of the dishwashers in the core libraries have been setup this way.  I think this is why they can be placed as free standing objects and will get an automatic counter now.
Most of the Core Library undercounter appliances don't currenty work properly.  They don't display flush with the cabinet fronts and many don't add a panel if at the end of a cabinet run.
I've reported this to Chief.
It appears all of the Manufacturer Libraries are properly updated but some items may have been missed.
  • 2 weeks later...
5 hours ago, raltd9245 said:
Very Bad Update by Programer who have nothing else useful to do. PLEASE CHANGE IT BACK CHIEF
Thankyou
Ron Ravenscroft
With all due respect sir, that's a pretty unfair statement to make about someone's craft & livelihood, presumably based on assumption. I have some frustrations with Chief just like all software but I've never gotten the impression that the people behind it are slacking or not putting the work in to try and improve the software, and I would bet it's quite the opposite situation than what you describe.
  • Like 3
I would agree.  In fact, I've been pretty impressed at how responsive Chief has been to the forum and also the tech support issues I have sent in.
They just released an update to X17 today.  I took a look at the change log out of curiosity and it's clear they are hard at work.
Jim
