GeneDavis Posted March 25, 2024 Share Posted March 25, 2024 Attached is a plan view of a kitchen with cabinets displayed. I drew two arrows to point out lines I cannot make go away. The cabinets both sides of these two lines are same type, height, distance off floor as adjoining cabinets. No other cabinet to cabinet lines are showing. Why these? Link to comment Share on other sites More sharing options...
robdyck Posted March 25, 2024 Share Posted March 25, 2024 Needless to say you'd need to post the plan so that someone could inspect and troubleshoot and then offer a solution. Link to comment Share on other sites More sharing options...
rgardner Posted March 25, 2024 Share Posted March 25, 2024 From experience with clients who like to place cabinets holding down the ctrl or cmd button, 99% of the time the cabinets are not precisely joining. Its hard to tell if its the quality of the screen gram but it looks like the upper cabinet was forced placed and is just very slightly pushed into the wall if the line at the front is indicative of its location. Use the bumping arrows to move away from the wall and the adjoining cabinet then bump it back into place and see if that is what is up. Otherwise post the plan. Link to comment Share on other sites More sharing options...
DBCooper Posted March 25, 2024 Share Posted March 25, 2024 Not sure why you would get the extra lines with the wall cabinets but like others mentioned, sloppy connections could easily cause that. The island looks like a very old Chief bug. If you have 2 cabinets bumped against the back of one other cabinet, you will almost always get an extra line. Someone at Chief told me years ago that cabinets can only make a one connection per side so anytime you have a side bumped against more than one cabinet you will get stray lines. The easiest way around this is to just turn on the module lines so you will see all of the boxes. Link to comment Share on other sites More sharing options...
tundra_dweller Posted March 25, 2024 Share Posted March 25, 2024 6 minutes ago, DBCooper said: The island looks like a very old Chief bug. If you have 2 cabinets bumped against the back of one other cabinet, you will almost always get an extra line. Someone at Chief told me years ago that cabinets can only make a one connection per side so anytime you have a side bumped against more than one cabinet you will get stray lines. This is good to know, I've spent a lot of time trying to chase down those lines over the years, usually end up masking over them or representing the island with CAD in plan view. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 26, 2024 Author Share Posted March 26, 2024 Here is the unstripped file. The issue is the kitchen wall cabinet to R of corner wall cab. Upper L corner of kitchen cabinets ell arrangement. Joint between. First time I have tried using WeTransfer, and hope it works. https://we.tl/t-B6840ozbKS Link to comment Share on other sites More sharing options...
TeaTime Posted March 26, 2024 Share Posted March 26, 2024 Interesting. Slide the cabinets above the stove out, grab the wall cab to the right of the corner cab, nudge it right, nudge it left. When it reconnects the line goes away. Not sure why it's doing it in the first place though. *Edit: Oh hey once those cabinets above the stove are moved back, the line returns. Hello, culprit. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted March 26, 2024 Solution Share Posted March 26, 2024 Easier solution. resize this one smaller then back again Link to comment Share on other sites More sharing options...
