RicatRandM Posted June 29, 2023 Share Posted June 29, 2023 Greetings, Having a difficult time reproducing this eve detail...any suggestions? Thanks in advance for you time. Ric PS Using version 15. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 29, 2023 Share Posted June 29, 2023 I am assuming it is the horizontally trimmed rafter tails you are having issues with ? If so you will need to apply a Rafter Tail Molding to your rafters and Gable Sub Fascia. Unfortunately I think you will need to omit the automatic Fascia for a build like that. 1 Link to comment Share on other sites More sharing options...
TeaTime Posted June 29, 2023 Share Posted June 29, 2023 That's what I was thinking too - unfortunately I don't think that's going to work exactly like the image because of the fascia and sub fascia. Chief can do Square or Plumb(vertical), but not plumb horizontal. Should file it under Suggestions. Link to comment Share on other sites More sharing options...
glennw Posted June 30, 2023 Share Posted June 30, 2023 8 hours ago, TeaTime said: Chief can do Square or Plumb(vertical), but not plumb horizontal. "plumb horizontal" - ???????? That's a new one on me! It must be regional thing. It must be a tad difficult to do "plumb horizontal" with a plumb bob. I guess you get the apprentice to go down to wallmart and ask for a horizontal plumb bob. Down here in Oz "plumb horizontal" is called level or horizontal. 1 1 Link to comment Share on other sites More sharing options...
glennw Posted June 30, 2023 Share Posted June 30, 2023 We can almost do a horizontal rafter tail automatically. But we are stuck with that pesky line on the underside of the rafters which is the invisible horizontal soffit meeting the invisible raking soffit. Link to comment Share on other sites More sharing options...
RicatRandM Posted June 30, 2023 Author Share Posted June 30, 2023 I set the facia to 1"...and can get it most of the way...but when I add the shadow board it extends down past the facia? DOOLIN FINAL MODEL PLAN 6.28.23 forum.pdf Link to comment Share on other sites More sharing options...
RicatRandM Posted June 30, 2023 Author Share Posted June 30, 2023 Also couldn't get a "flat" soffit to work? Link to comment Share on other sites More sharing options...
RicatRandM Posted June 30, 2023 Author Share Posted June 30, 2023 Here is a section view...but doesn't show the shadow board... I can't get to a "point" but if I use a 1" facia and change a little framing in the "structural" tab...I can get it close enough. But the shadow board continues down past the facia as in the previous layout? Link to comment Share on other sites More sharing options...
Chrisb222 Posted June 30, 2023 Share Posted June 30, 2023 6 hours ago, glennw said: I guess you get the apprentice to go down to wallmart and ask for a horizontal plumb bob. Yep, we got those. Right next to the Sky Hooks. Link to comment Share on other sites More sharing options...
SNestor Posted June 30, 2023 Share Posted June 30, 2023 I gave it a shot. Not perfect...but I think close enough. 1 Link to comment Share on other sites More sharing options...
RicatRandM Posted July 5, 2023 Author Share Posted July 5, 2023 Thank you all for your time. Link to comment Share on other sites More sharing options...
