Breeze_Design Posted May 5, 2023 Share Posted May 5, 2023 Curious if anyone else has seen this behaviour: I find that if I leave CA X15 open for a while on my desktop, I am unable to select items using the mouse. All items are affected, cabinets, dimensions strings, walls, etc. I CAN select them using the marquee method. This is remedied by closing the program and re-opening the plan. It then works for a while, but the issue occurs again if I leave my PC for a brief period and return to an open plan. I have logged a case with support and waiting on a reply Link to comment Share on other sites More sharing options...
Kbird1 Posted May 6, 2023 Share Posted May 6, 2023 20 hours ago, Breeze_Design said: I find that if I leave CA X15 open for a while on my desktop Not sure what you mean by " a while" but there has always been an unwritten Rule to Restart Chief during the Day eg when going to lunch, to help stop "weirdness" ( a memory leak I think ) but not sure if that is what you are experiencing or not? I have not seen this myself but am still doing a lot of work in X14. M. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 6, 2023 Share Posted May 6, 2023 i have seen this on x14 Link to comment Share on other sites More sharing options...
jonboy Posted May 6, 2023 Share Posted May 6, 2023 Happens to me Link to comment Share on other sites More sharing options...
someguy Posted May 6, 2023 Share Posted May 6, 2023 You can use the tab key to help select objects. It will cycle through anything close to where the cursor is. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 6, 2023 Share Posted May 6, 2023 1 hour ago, someguy said: You can use the tab key to help select objects. It will cycle through anything close to where the cursor is. This is a different case. Nothing gets selected Link to comment Share on other sites More sharing options...
Breeze_Design Posted May 9, 2023 Author Share Posted May 9, 2023 Support had me update the Nvidia Studio driver but that has NOT resolved the issue (I had been still running the November version as there were significant issues with them after that one). 1 Link to comment Share on other sites More sharing options...
justinorwig Posted May 17, 2024 Share Posted May 17, 2024 Hi Not sure if I am having the same issue. I am happily using a Mac book pro on X15 and lately the cursor is selecting stuff WAAAYYY too far away. It will usually prioritize dimensions over objects so I have to zoom way in to try to get the object selected vs whatever else it is trying to grab. Its like the field of the cursor is way to wide and not referencing the closest object tot the point of the cursor. Am I over looking a setting? Link to comment Share on other sites More sharing options...
DBCooper Posted May 17, 2024 Share Posted May 17, 2024 Is this a problem with one particular plan or with all plans? If it's just one plan, it could be something strange going on in the plan and you could always post it to see if someone else can see the problem. If it's all plans, then I don't have any ideas other than calling tech support. Link to comment Share on other sites More sharing options...
glennw Posted May 18, 2024 Share Posted May 18, 2024 Quote Hi Not sure if I am having the same issue. I am happily using a Mac book pro on X15 and lately the cursor is selecting stuff WAAAYYY too far away. It will usually prioritize dimensions over objects so I have to zoom way in to try to get the object selected vs whatever else it is trying to grab. Its like the field of the cursor is way to wide and not referencing the closest object tot the point of the cursor. Am I over looking a setting? Have a look in Preferences>Edit>Snap Properties>Snap Distance What is the distance set to? Link to comment Share on other sites More sharing options...
BryanXG Posted May 20, 2024 Share Posted May 20, 2024 I'm also experiencing ,mouse/selection issues... you can't just click on an item to select it, you have to click and hold for a second or two for the item to be selected. Immediately after upgrading to x15 the mouse was freezing for periods of up to 15sec, but after several reboots only seems to have the selection delay now. Link to comment Share on other sites More sharing options...
