Best Practices Question
JKEdmo
Go to solution Solved by scottharris,
I have a quick question:
I've read that drawing walls in a clockwise manner is recommended practice.
I was wondering why and if this is still relevant with latest releases such as X15.
Thank you,
Jim
  • Solution
Drawing exterior walls clockwise can keep the outside layer on the outside.  If you draw them counterclockwise, once a room is formed, the walls will auto adjust to the outside.  So, it may not really matter which way you draw them.
Thank Scott.
I was not aware walls will "flip" to outside when forming a room.
Jim
I think it became "Automatic" in X12  ( someone will correct me no doubt :) ) , it's one on the Options quickly accessed by Alt-Q
( General Wall Defaults ), I think it's still a good Practice , since CA doesn't always get it right , but then I am used to it and it is SOP.
9 hours ago, Rich_Winsor said:
I believe the "recommended" practice is to draw walls in
a clockwise direction in the northern hemisphere and in a
counterclockwise direction in the southern hemisphere. :rolleyes:
What if you are on the equator?  :)
Thanks to all.  Jim
