ACADuser Posted January 31, 2023 Share Posted January 31, 2023 How do you deal with these unwanted lines in vector view? Link to comment Share on other sites More sharing options...
Chopsaw Posted January 31, 2023 Share Posted January 31, 2023 It appears as though you are properly aligned so it must be a material issue. If the materials are actually supposed to be different then technically you should have a division line right ? Link to comment Share on other sites More sharing options...
ACADuser Posted January 31, 2023 Author Share Posted January 31, 2023 Thanks for looking at this. The wall inside is drywall from the core catalog & both are 5/8. Link to comment Share on other sites More sharing options...
PhillipsPlans22 Posted February 2, 2023 Share Posted February 2, 2023 Are the walls interior surfaces in line? If its off a little it will show a line Link to comment Share on other sites More sharing options...
VisualDandD Posted February 2, 2023 Share Posted February 2, 2023 In my experience chief generates all kinds of those in vector view. (they dont appear in the standard render) I deal with them in 2 ways. 1- for most exterior elevations, I send to layout as plot lines and then delete the small unwanted lines. 2-for most interior sections, I 'create cad detail from view' and do the same....delete unwanted lines. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 2, 2023 Share Posted February 2, 2023 Sometimes those types of line disappear when you actually print it. Link to comment Share on other sites More sharing options...
ACADuser Posted February 2, 2023 Author Share Posted February 2, 2023 No luck this time Perry. I usually drop a plume mask over them rather than edit them away as any refresh & I forget to do it again. Link to comment Share on other sites More sharing options...
joey_martin Posted February 3, 2023 Share Posted February 3, 2023 Just delete them in layout. Link to comment Share on other sites More sharing options...
ACADuser Posted February 3, 2023 Author Share Posted February 3, 2023 I do, over & over & over again as I update all layout boxes. Until the final print, Oh Sh*t I forgot the last time. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 4, 2023 Share Posted February 4, 2023 On 1/31/2023 at 1:47 PM, ACADuser said: Thanks for looking at this. The wall inside is drywall from the core catalog & both are 5/8. This doesn't necessarily mean that they're using the same material. You can have 2 materials with the same name. Link to comment Share on other sites More sharing options...
ACADuser Posted February 4, 2023 Author Share Posted February 4, 2023 When I click on each one they open in the core catalog at the same place. I suppose I could select each time to be sure they are the same? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 4, 2023 Share Posted February 4, 2023 12 minutes ago, ACADuser said: When I click on each one they open in the core catalog at the same place. I suppose I could select each time to be sure they are the same? Click on Plan Defaults and see what they say in there. Link to comment Share on other sites More sharing options...
Solution ACADuser Posted February 4, 2023 Author Solution Share Posted February 4, 2023 If you flip the 4" wall with the "Reverse Layer" tool so both primary sides are on the same side the line goes away. 1 Link to comment Share on other sites More sharing options...
