MIKE202020 Posted August 20, 2022 Share Posted August 20, 2022 CAN ANYBODY TELL ME HOW TO CREATE CUSTOM WALL OPENING IN CHIEF ARCHITECT Link to comment Share on other sites More sharing options...
Chopsaw Posted August 20, 2022 Share Posted August 20, 2022 Do you have an example or can you describe the characteristics of the opening ? There may be a few options other than a door or window. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 20, 2022 Share Posted August 20, 2022 Also it may depend on what version you are using so filling out you signature with that information would be helpful. Link to comment Share on other sites More sharing options...
MIKE202020 Posted August 20, 2022 Author Share Posted August 20, 2022 i am using chief architect premier x10 Link to comment Share on other sites More sharing options...
glennw Posted August 20, 2022 Share Posted August 20, 2022 Have a look into "Inserts Into Wall" for a symbol (which you can hide). And then select the symbol and use "Edit Wall Cutout Polyline" from the Edit menu. You can drag the wall hole around and edit it to any shape. Its a little tricky to use the first time but once you know how, you can cut any shape you want. It works the same in X10. Link to comment Share on other sites More sharing options...
MIKE202020 Posted August 20, 2022 Author Share Posted August 20, 2022 Thank you for your help... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 20, 2022 Share Posted August 20, 2022 8 hours ago, M-Reed said: Mike, another way that may interest you is to create a symbol using a polyline for the outline. This then can be converted to a door symbol with all the benefits of such (eg: door jamb, door slab, with their own materials and colors, etc. Also height and width adjustment as well as location in the wall.Their is no reason a door opening has to be a rectangular shape.... It has always been the crowning feature of Chief's tool sets, to do much more than is apparent. Can you expand on this? Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 19, 2023 Share Posted July 19, 2023 I have an arch I created in 2D CAD, converted to a solid, converted to a symbol, and set the "Inserts Into Wall" but when I put it on the wall, it cuts a rectangle instead of the arch. Any idea why? symbol: plan view: then I move the symbol to the left over the wall and widen it and I get a rectangular cutout: then I deselct the layer for the symbol Any ideas why I do not get the arch? btw I tried the pass through window and door for the arch, but the bottom sill always showed 694 Muirfield Cr - fe (3).zip Link to comment Share on other sites More sharing options...
Chopsaw Posted July 19, 2023 Share Posted July 19, 2023 Jason when you select the symbol does this tool show up on the active toolbar ? Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 19, 2023 Share Posted July 19, 2023 i placed it from my library onto the wall in elevation. When I click on it, in elevation, i get which now I notice has the "convert to symbol" but missing the icon so I did it again, selected the 3d solid, click to convert to symbol, a dbx pops up with a checkbox to add to library, which I check, except I also check the advanced options , and check to insert into wall (where before I opened up in the library and checked it). then I select it from my library and when I place it it, low and behold, it cuts into the wall. Then I went back to my original in my library and placed it on the wall, and now it cuts the wall, without having to move it in plan view go figure anywho, it is still the same look (square cutout), but I have that menu item now, if I click the symbol , I get interesting that it has "convert to symbol" but now what do i do, I dont see something that will cutout the arch instead of the box I currently have Link to comment Share on other sites More sharing options...
Chopsaw Posted July 19, 2023 Share Posted July 19, 2023 Perfect convert the top of the cutout polyline to an arc and match it to the symbol. It should be automatic but this is much more satisfying. Link to comment Share on other sites More sharing options...
rgardner Posted July 19, 2023 Share Posted July 19, 2023 Just curious why you don’t just use a doorway to accomplish this? 3 hours ago, SHCanada2 said: I have an arch I created in 2D CAD, converted to a solid, converted to a symbol, and set the "Inserts Into Wall" but when I put it on the wall, it cuts a rectangle instead of the arch. Any idea why? symbol: plan view: then I move the symbol to the left over the wall and widen it and I get a rectangular cutout: then I deselct the layer for the symbol Any ideas why I do not get the arch? btw I tried the pass through window and door for the arch, but the bottom sill always showed 694 Muirfield Cr - fe (3).zip 7.83 MB · 1 download Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 19, 2023 Share Posted July 19, 2023 1 hour ago, rgardner said: Just curious why you don’t just use a doorway to accomplish this? 5 hours ago, SHCanada2 said: btw I tried the pass through window and door for the arch, but the bottom sill always showed do you know how to get rid of the bottom doorway sill? or maybe I wasnt doing it right 1 hour ago, Chopsaw said: Perfect convert the top of the cutout polyline to an arc and match it to the symbol how does one "match it to the symbol...easily...go chase down the properties from the original arc and plug them all in? after getting frustrated with that....I created a couple psolids, and subtracted them, which worked ...after taking 20 minutes trying to place the psolids in the right place to begin with. For some reason I couldn't find them on the plan view(yes the layer was on) for that long, and I was moving them around in circles in 3D. No idea why they werent in plan view. But even so, I think I need to watch some videos on how to move psolids around in 3D..literally I was moving them in circles (I'd move the camera to be more or less on one elevation, then move it, then move the camera to another elevation then move it, then move the camera to be on top and then move it, rinse repeat) ...there must be a proper technique that I am missing that being said, I'd like to see if I can get the symbol thing going ...or the pass-thru doorway/window. The latter seems the simples if it could work...and that is where I got the arc from to begin with for the psolid Link to comment Share on other sites More sharing options...
Chopsaw Posted July 19, 2023 Share Posted July 19, 2023 Sorry I missed a step.... 2023-07-19 01-28 AM (2).mp4 Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 19, 2023 Share Posted July 19, 2023 3 hours ago, SHCanada2 said: do you know how to get rid of the bottom doorway sill? or maybe I wasnt doing it right Turn Sill/Threshold off in the Casing Panel? Link to comment Share on other sites More sharing options...
rgardner Posted July 19, 2023 Share Posted July 19, 2023 8 hours ago, SHCanada2 said: do you know how to get rid of the bottom doorway sill? or maybe I wasnt doing it right Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 19, 2023 Share Posted July 19, 2023 thanks , that little arrow on the arc is the trick. and to rene and ryan, thanks...not sure how I missed that...late night ... Link to comment Share on other sites More sharing options...
