DeLayDesign Posted June 12, 2022 Share Posted June 12, 2022 Has anyone else experienced an issue with the wall cap on a pony wall? Nothing I do allows it to continue down the wall past the door. Any suggestions outside of just drawing it manually w/ a molding? TIA. *I have a ticket into Chief about this as well. Link to comment Share on other sites More sharing options...
glennw Posted June 12, 2022 Share Posted June 12, 2022 You are wanting something that wall caps don't do. 2 2 Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 12, 2022 Share Posted June 12, 2022 You have two equal-thickness masonry wall types stacked making or leaving NO room for a visible "wall cap". Make the upper masonry wall thinner and then perhaps the wall cap will be visible between them. DJP 3 Link to comment Share on other sites More sharing options...
DeLayDesign Posted June 13, 2022 Author Share Posted June 13, 2022 Hmm... Actually I've done the same tech. without issues in X13. It works fine on other walls, but when the door is introduced it causes the issue. Also wall caps can be used as 'face applied' items or full wall split. This is a face applied molding. 1 Link to comment Share on other sites More sharing options...
rgardner Posted June 13, 2022 Share Posted June 13, 2022 Hard to see with the standard rendering. Turn on vector or line overlay on standard for better pix. As it’s hard to see in that pic just want to confirm that you have that applied as a wall cap. That is one continuous wall and not broken at the door and the foundation wall below it is continuous and aligned properly and is square 90degrees? Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 13, 2022 Share Posted June 13, 2022 Sometimes when walls below or above are not inline they can produce all sorts of chaos. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 13, 2022 Share Posted June 13, 2022 "No Molding on Selected Edge" ??? Link to comment Share on other sites More sharing options...
DeLayDesign Posted June 17, 2022 Author Share Posted June 17, 2022 I was told I was using a 3D object that had too many faces to it. I did receive this warning when I opened the plan after closing it but thought nothing of it. I was trying to use a 'live edge' to get a more realistic look to the stone cap. When I changed it back to a normal molding the issue resolved itself. Thanks @ChiefArchitectfor the explanation. Link to comment Share on other sites More sharing options...
