Chief automatically lowers sill plate for stem wall
Go to solution Solved by Kbird1,
Hi All,
I have what should be a very straightforward case: I have a rectangular existing house with a full basement and an addition with crawl space at a lower elevation, 7" in my case. Chief automatically lowers the stem wall of the main house for the stem wall segment between the addition and the main house while also creating a jog with the rim joists. I have not been able to figure out how to control this behavior. If I manually edit the stem wall in a section view then for some reason the sill plates disappear from that wall altogether...
X13 on MacBook Pro. Plan file attached.
1795055767_ScreenShot2022-05-27at2_02_35PM.thumb.png.dbea14b96622617cef40b0f14370ec59.png
1991508538_ScreenShot2022-05-27at2_07_56PM.thumb.png.99e3557fb9dd0ef2ea1e499e70eb1af6.png
1526557181_ScreenShot2022-05-27at2_07_35PM.thumb.png.682327c0236df9e345d1884b1f190d26.png
1528999955_ScreenShot2022-05-27at2_09_20PM.thumb.png.ad99075e24bbe6d5fabf6cbe30550e9a.png
Many thanks in advance for your help.
Stem Wall Sample Plan.plan
2 Things.
1) Try reversing the Main Layer of the interior wall to match the main outside layer of the exterior walls. If that doesn't work...
2) simply grab that segment of foundation wall in 3D and drag it up to snap into place at the correct elevation.
21 hours ago, joey_martin said:
He isn't using a slab...
No, I just thought it maybe worth a try even so..... as CA's Settings sometimes act in unexpected ways....
* see below it does work at least in this case.
 In that situation I always put a Smaller scoop footing between the new and old, draw the footings as a box, then move the footing between the new and old right up against the old footing. this has been around forever.
  • Solution
Okay had a few minutes to look at this and it seems to work okay with the right settings for me........  ( in X14 at least )
ie the Addition set at -7" as mentioned in the OP ( was at 1.75")  and the Pour/Framing group set to 2  ( mentioned above ) in the Addition Room DBX also.
image.thumb.png.255b5784f0368820923062667cf068f1.png image.thumb.png.2992a3964ff96b03336860e62269f83f.png
Nice Mick. Need to remember that pour number setting.
Thanks, Larry , it works similar to the Roof Groups setting but is sometimes hit and miss.....
Personally I am not afraid to try things like that, as there is always the UNDO Button :)       ( set to 50 min.)
( or I do a Save As Plan to try things on)
I thought if you did this you would lose the auto sill Plate.
Nice job Mick.
    32046
    BDecker
    BDecker
  • Similar Content
    • By BlackDiamond
      I've never done monolithic slabs and am having issues with the foundation plan. This is a house for southern Florida so has 8" exterior block walls.
      For some reason, only the garage and common walls with patios are showing up. For the life of me I can't figure out why the exterior walls of the house are invisible. They are the same wall type. I need all the foundation plan walls to look like what the garage walls are showing.
      I'm sure I'm missing something....
      Thanks
      Beth Revised.zip
    • By Doug_N
      This post moved to suggestions.
    • By MN_JohnH
      I am trying to construct a home on a slab and I am going to use ICF walls around the perimeter with footings. The bottom of the footing needs to be 52" below grade and the interior of the icf walls are filled in and the slab is poured either on top of the ICF walls or inside the ICF walls. All the tutorials show how to make a slab foundation or a crawlspace but I don't see an option for a stem wall and footing below the slab without a crawlspace.
    • By pj42pj42
      I had a problem aligning the Foundation, the Sill plate and the Framing.  The problem started after I finally got Sill plate to
      appear as Used in Layers. After more than one day of no progress I decided to restart and build a new plan from scratch.
      I went through defaults on the new plan repeatedly before starting any drawing. Sill plate is not yet indicated in layers as Used. (For that matter, Foundation is not yet indicated as Used) The Framing has not started yet, but there is already a lot of difficulty just aligning the foundation to the first floor.  When the Foundation wall is being traced over the Reveal floor outline, the square Endpoint indicator aligns the Foundation wall to roughly the middle of the Reference wall, not the exterior edge.
      I tried re-sizing the foundation wall lengths to the correct dimensions, after re-sizing the two floors are the same size but are still not aligned with each other.  (I started by extending the first wall in both directions. Each subsequent wall was extended away from the first by using the arrow indicators for dimension re-sizing)
      I tried applying a 5" Foundation offset in the Foundation wall definition.  The square Endpoint continued to register ~5" away from the exterior edge of the first floor Reference wall line.
      I tried applying a 5" Bridge ledge in the Foundation wall definition. The Foundation wall continued to mis-align with the reference wall above.
      If I try to manually move the foundation wall, CA won't allow a perfect overlap.  Maybe this has something to do with snaps.  The snap settings are all default, I've tried to understand snaps but so far not enough to attempt changing anything.
      Any help greatly appreciated,
      Pedro
      Plot2V1_2018_07_29.plan
    • By gdesignbuild
      I am just working on a masonry garage design, and have been held up trying to figure out some details. One is for steel lintels that I am putting over the openings. The closest thing that you can use as a header type is a steel-box but I will be using steel angle. The header column shows the dimensions including the length of your lintel but only gives 1.5" on each side of the opening. Is anyone familiar with a way that I can change this to more? Otherwise, I will just remove that column and leave a note in the comments.
      Second issue: When you pull your cross sections from a CMU building, it shows your trusses sitting right on the block. For now I have manually drawn my plate in with an anchor but I was curious if there is a way to do this as well?
