Member Statistics
Similar Content
By SMB2021
Since upgrading to x14 at least 2 of my co-workers in my department are having a text issue when saving as a PDF. I have not had the issue they're having but it's becoming an "inconvenience" that if they need something sent to PDF, those of us not having the issue will have to open the file and do it for them.
I've attached some pictures of the issue vs what it's supposed to look like.
Is anyone else having this issue and knew the solution to fix it?
How it looks when they send to PDF
vs how it looks when I send to PDF
By SNestor
I have a new video that shows how my "Screened Porch Library" for Chief Architect Premier works with X14...and it works great.
It's the easiest and fastest way to create custom looking Screened Porches...and if you are using X14 you can now see through the screen into to room. Fantastic new improvement the engineers at Chief have brought us.
Have a look...
By Designers_Edge
1. YES, I have read Chief Architect's X14 migration guide.
But I want to dive deeper. I would love to know the way you prepare to move things over. Do you go through and clean up files? Do you move some files to an X13 folder that are no longer needed, but "just in case". What about your templates you have created for Layout? Do you clean up your library?
I know we all approach this differently. I have been using Chief Architect since Chief version 8. So, have done a lot of migrations, but always feel at times it could be done more neatly, cleaner.
Would love to hear your approach.
By basilbabaa
SITUATION: X13 3D renders, when compared to X12, appear blurred, washed out, less vibrant in quality and the vector renders have excessive line weights in X13
Rather than hijack a previous topic thread, I am starting this topic as a result of a side conversation that emerged here-in:
It appears that there are others experiencing this same issue, and so I thought I would begin this here in it's own topic thread.
Here is a Dropbox link to image and video files (generated on both a i9 and M1 Pro Max chips) depicting the issue: https://www.dropbox.com/sh/9zt4tagbuhsfkbi/AABsTnIW6DjT5uExeP6e5mcAa?dl=0
As a note, I have already opened a support case with Chief Technical Support and they have graciously offered to look into it:
If anyone else is noticing lesser quality output with 3D rendering in X13 as compared to X12, perhaps we can share our experience and thoughts here as well as with support towards a workable solution.
By Renerabbitt
Do you have 10+ years in the software and wonder if you've been missing some tips and tricks? Have you been able to break the 15 hour condoc set?
Maybe you are a proficient user that wants to know everything that there is to know in Chief.
Rendering, Automation, Resources, Symbols, Quick Tools, Style Pallets, PDF Tools, Templates, and more.
We believe in lifting the community up. All of our tools and resources are available to you. With training that can be personal, team oriented, prerecorded, livestreamed, interactive. We offer training in over 15 softwares from Drafting and Detailing to Modeling, Advanced Texturing, Procedural Workflows, Node Based Design, Macro Creations, DAMs, Automation, VR Workflows, Streaming Overlays and Masks and much much more. Tell us your needs and we will connect you with the package or the right resource.
Some example learning modules:
Concentric Jump your dimension strings
Enter-input your jumps and Enter-close your DBX's
Snap jump your door widths, concentric jump your windows
Alt behavior tips, contain-selection and deselection workflows with tool restrictions.
Tons of cabinet tools and tips, including custom one-off parametrically modelled vanities and more.
Custom Toolbar Icons and Custom Library Objects.
Toolbar Switching Tricks and Library workflows
Other Offer Services Posts:
