Curved Cabinets
BruceKC
I can see some pretty straight lines there in the cabinets or at least the back panels.
Definitely a curved custom countertop but that is pretty straight forward.
No point in spending tens of thousands extra unless that is exactly what the client wants.
It looks to me like 4-5 straight sections with a curved top.
  • Upvote 2
Its pretty quick to make honestly. Took me maybe 8 minutes
Yes I understand and appreciate that Rene.   The problem is there is quite a distinct difference between "making" something and "drawing" something.
The posted image creates quite a dramatic effect without using curved cabinets is my other point.
  • Upvote 2
Aha! I didn't pick up on the distinction. Yes, hard sell to convince my cabinet quy to touch that. He happens to be right here next to me. Says he would used premade bowed doors as rear panels.
Yes I think it could look better than the example by doing that. :)  The example appears to be 48" straight panels mounted on a wall to support the upper bar top but cutting that down to 24" and curving it would help create the illusion.  Not quite sure what they did on the inside as you can't see much more than the water faucet neck but the back of those cabinets would be completely hidden anyway.
  • 2 years later...
I did some great curved cabinet videos back in the day but I cannot find them now.
I would create the shape of cabinet in plan view via cad lines and arcs,  using the info from the curved lines ,  I could then shape the cabinet.
The real key is being able to define the BOW DEPTH via the CAD layout.
If I remember correctly,  I could do just about anything I wanted.
1 hour ago, villadecordesign said:
Does anyone know how to create one like I have here in our inspiration photo?
I think the issue is that what you show is angled AND bowed, yes? That can't be done as a single cabinet but can be done, at least I couldn't. It can be done but tricky...hHere is pic and file. Bottom moldings and feet will need attention as will side door panel. This can be blocked or perhaps turned into a symbol for multiple use. I didn't go that far, this kept me amused long enough :)
Angle curved cabinet.zip
