Doug_N Posted February 17, 2022 Share Posted February 17, 2022 One more question, does this only happen with NVidia? Any of your experiencing this with AMD or any other cards? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 17, 2022 Share Posted February 17, 2022 6 minutes ago, Doug_N said: One more question, does this only happen with NVidia? Any of your experiencing this with AMD or any other cards? Me? Chief has always recommended Nvidia Gaming cards , so that is what I have always had...... looks like buying a 3080 in the new computer for X13 was a waste of hard earned $$$ though..... probably lost an hour today already with lockups.... M. Link to comment Share on other sites More sharing options...
BigKahuna Posted February 21, 2022 Share Posted February 21, 2022 On 11/30/2021 at 10:54 PM, Kbird1 said: Not working on a Laptop ( make sure you don't have overheating issues ) but do have a 3080 and have found since the last release that the crashes seem to be all in older plans started in X12 , and usually in a 3D Camera , eg trying to use Mouse Orbit to rotate the Model. Mick. Thats my issue older plans trying to use in 13. For now I only open older files in x12 until they hopefully find a fix Link to comment Share on other sites More sharing options...
BigKahuna Posted February 21, 2022 Share Posted February 21, 2022 On 12/1/2021 at 12:25 PM, Kadoyle8 said: Thanks! That sounds typical of my experience - if I'm asked to replicate it, the program works perfectly, but the second I want it to cooperate, the error is constant. It leaves the program functional, but extremely frustrating and challenging to accomplish work. It works moderately more reliably when on the laptop screen only, and not connecting to additional monitors. I have submitted the requested logs and files for two different computers that experienced this issue, so hopefully we all can all reach a solution soon. second monitor seems to be worse for me as well Link to comment Share on other sites More sharing options...
frameworks Posted May 26, 2022 Share Posted May 26, 2022 Hello, We are currently experiencing this error on our MSI Raider GE75 Laptop Specs: CPU: Inteli7 10750H 2.6GHZ GPU: NVIDIA RTX2070 RAM: 16GB 3000MHz Windows 10 Here is a copy of the error message. C:\perforce\ryanm\dev\Astral\Releases\1.2\Astral\AstralRender\Engine\RenderingPipeline.cpp(184): Error #272032750 "An internal rendering error has occurred and the program will terminate: Device Removed" 5/26/2022 9:58:18 AM Build: 23.3.0.81x64 This laptop has run flawlessly in chief (out of chief it can be hit and miss) but just today it started with this error and has done it a good ten times since this morning. I found it interesting I haven't seen anyone else mention a 20 series GPU yet. I did try to uninstall and reinstall x13 with no good results. Hope this helps in some way, as I have no solution. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 27, 2022 Share Posted May 27, 2022 21 hours ago, frameworks said: Hello, We are currently experiencing this error on our MSI Raider GE75 Laptop Specs: CPU: Inteli7 10750H 2.6GHZ GPU: NVIDIA RTX2070 RAM: 16GB 3000MHz Windows 10 Here is a copy of the error message. C:\perforce\ryanm\dev\Astral\Releases\1.2\Astral\AstralRender\Engine\RenderingPipeline.cpp(184): Error #272032750 "An internal rendering error has occurred and the program will terminate: Device Removed" 5/26/2022 9:58:18 AM Build: 23.3.0.81x64 This laptop has run flawlessly in chief (out of chief it can be hit and miss) but just today it started with this error and has done it a good ten times since this morning. I found it interesting I haven't seen anyone else mention a 20 series GPU yet. I did try to uninstall and reinstall x13 with no good results. Hope this helps in some way, as I have no solution. My laptop has the 2070 and occasionally has this crash as does my 3080/3080Ti Desktop system , it is not the GPU but some Driver maybe worse than others , I am try 512.59 Studio at the moment but there was a new Driver a few days ago I declined , so perhaps that was the catalyst for your issue? M. Link to comment Share on other sites More sharing options...
SamPWB Posted August 27, 2022 Share Posted August 27, 2022 Anyone having this issue in X14? I'm getting this more often that I would have hoped with my new laptop. Specs: MSI Raider GE76 12UGS CPU: 12th Gen Intel(R) Core(TM) i7-12700H 2.70 GHz GPU: NVIDIA RTX 3070Ti RAM: 32.0 GB Windows 11 Link to comment Share on other sites More sharing options...
DarlingInc Posted January 22, 2024 Share Posted January 22, 2024 Its now 2024 and I'm having this issue for the first time. Windows 10 pro, 64. Working off the hard drive not the cloud. Any solutions found yet? RenderingPipeline.cpp(193): Error #272032750 "An internal rendering error has occurred and the program will terminate: Device Removed" Build: 25.3.0.77 Windows 64-bit Link to comment Share on other sites More sharing options...
WCjake Posted October 16, 2024 Share Posted October 16, 2024 Hi, random lurker here for years, but I think this is actually my first post here. I've been using X13 since its release with no issues on a daily basis, and was working on a house plan tonight and went into a wall specification panel to change the exterior material. When I switched from siding to stucco the program froze and gave me the following error C:\p4sync\ryan3070\dev\Astral\Releases\1.2\Astral\AstralRender\Engine\RenderingPipeline.cpp(184): Error #272032750 "An internal rendering error has occurred and the program will terminate: Device Removed" 10/15/2024 9:38:19 PM Build: 23.4.1.8x64 I thought it was a random fluke and restarted the program, but this issue happens every time I change the wall material now, and I haven't been able to find a solution. I've tried about 20-30 times now in different ways and it consistently locks up and makes the program close. I searched the forum and this seems to be the closest thread to my issue. Does anyone know what the issue is and how to fix it? The following are my system specs, let me know if I missed anything. Motherboard - MSI B760 Processor Intel(R) Core(TM) i7-14700K 3.40 GHz Graphics Card - GIGABYTE GeForce RTX 4070 WINDFORCE OC 12G Graphics Card Installed RAM - Silicon Power DDR5 32GB (2x16GB) Zenith 6000MT/s (PC5-48000) Main SSD - Crucial P3 Plus 2TB PCIe Gen4 System type 64-bit operating system, x64-based processor Operating System - Windows 11 Pro Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 16, 2024 Share Posted October 16, 2024 did your system auto update the video card driver? Link to comment Share on other sites More sharing options...
WCjake Posted October 23, 2024 Share Posted October 23, 2024 Yes, I checked in the update history and this is what i found What would you recommend to fix this? Thanks! Link to comment Share on other sites More sharing options...
WCjake Posted November 15, 2024 Share Posted November 15, 2024 Still having this issue and its been happening more often, like every 4 minutes now. Does anyone have any ideas to fix this? Link to comment Share on other sites More sharing options...
WCjake Posted November 15, 2024 Share Posted November 15, 2024 Link to comment Share on other sites More sharing options...
DBCooper Posted November 15, 2024 Share Posted November 15, 2024 Quote Still having this issue and its been happening more often, like every 4 minutes now. Does anyone have any ideas to fix this? Dude, you replied to a post that is over 2 years old. Whatever problems they were having with the nvidia drivers back then are probably not related to the problems you are having now (other than it is also a video card or driver problem). First, try checking out this tech article: https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html If that doesn't help you, then you should probably contact tech support. I think they will charge $125 you since you are using an older version but it might be worth it if you are crashing every 4 minutes. 1 Link to comment Share on other sites More sharing options...
