ChiefuserMathews Posted October 12, 2021 Share Posted October 12, 2021 Hello, how can I show the sliding window opening direction in the elevation (like the arrow pointing which direction it opens)? Link to comment Share on other sites More sharing options...
Kiwideziner Posted October 12, 2021 Share Posted October 12, 2021 In X13 it shows auto matically when layer window openings is on. In x12 manual arrows drawn on the elevation. 1 Link to comment Share on other sites More sharing options...
SH_Canada Posted February 11, 2022 Share Posted February 11, 2022 I don't see "windows opening" layer. Is it somewhere else: Link to comment Share on other sites More sharing options...
joey_martin Posted February 11, 2022 Share Posted February 11, 2022 Link to comment Share on other sites More sharing options...
SH_Canada Posted February 11, 2022 Share Posted February 11, 2022 merci! Link to comment Share on other sites More sharing options...
SH_Canada Posted February 11, 2022 Share Posted February 11, 2022 FYI for others, also need to set in dbx Link to comment Share on other sites More sharing options...
CV-reno Posted February 11, 2022 Share Posted February 11, 2022 I find I have to go through every kind of opening in the default settings to set that parameter. Would have been nice to have a 'global' value for this, still allowing an override on each opening, or maybe I missed it ? Link to comment Share on other sites More sharing options...
glennw Posted February 11, 2022 Share Posted February 11, 2022 1 hour ago, CV-reno said: I find I have to go through every kind of opening in the default settings to set that parameter. Would have been nice to have a 'global' value for this, still allowing an override on each opening, or maybe I missed it ? You can do that in the Window Defaults and then use the windows dbx to toggle the display of indicators on an individual basis. 2 Link to comment Share on other sites More sharing options...
Dermot Posted February 12, 2022 Share Posted February 12, 2022 Sliding windows and doors will have the opening indicators turned on by default if you are using the template plan that ships with X13. If you migrated your template plans forward, or you are bringing in a plan that started in an earlier version, they will be off by default. This was done so that plans would not change unexpectedly when you opened them in X13. If you would like to show the opening indicators for sliding doors and windows for your legacy plans or templates, just turn them on in your door and window defaults. Keep in mind that you can also group select and edit your defaults if you would like to turn them on for more than one at a time. You should normally keep the windows and doors that are placed in your plans set to "use default" unless you need to override them for some kind of special situation. Link to comment Share on other sites More sharing options...
CV-reno Posted February 13, 2022 Share Posted February 13, 2022 On 2/11/2022 at 5:49 PM, glennw said: You can do that in the Window Defaults and then use the windows dbx to toggle the display of indicators on an individual basis. If one really wants to have all the openings indicated by default, not just windows but also doors interior and exterior (sliding, pocket, etc.), one needs to go into each of these defaults. My point is that theer's no global setting that applies to any type of opening. Link to comment Share on other sites More sharing options...
CV-reno Posted February 13, 2022 Share Posted February 13, 2022 On 2/11/2022 at 9:29 PM, Dermot said: Sliding windows and doors will have the opening indicators turned on by default if you are using the template plan that ships with X13. If you migrated your template plans forward, or you are bringing in a plan that started in an earlier version, they will be off by default. This was done so that plans would not change unexpectedly when you opened them in X13. If you would like to show the opening indicators for sliding doors and windows for your legacy plans or templates, just turn them on in your door and window defaults. Keep in mind that you can also group select and edit your defaults if you would like to turn them on for more than one at a time. You should normally keep the windows and doors that are placed in your plans set to "use default" unless you need to override them for some kind of special situation. Yes, I did migrate from earlier templates. Thanks for the heads up. Link to comment Share on other sites More sharing options...
