KingsOwn Posted September 1, 2021 Share Posted September 1, 2021 I have a problem in one file where windows drop out, or are deleted when I place a new cabinet or adjust an existing cabinet that is against the wall containing the window. Anyone had this happen. Any solutions? Thanks. Ian Link to comment Share on other sites More sharing options...
Kbird1 Posted September 1, 2021 Share Posted September 1, 2021 I think people will need to see the plan for this one , it isn't one I have heard of before as you can definitely put cabinets over windows in X13, at least in a New Plan from the Residential Template. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 1, 2021 Share Posted September 1, 2021 2 hours ago, KingsOwn said: Anyone had this happen. NO, please post a copy of your problem plan and a more detailed explanation of what you are doing please. DJP Link to comment Share on other sites More sharing options...
rgardner Posted September 1, 2021 Share Posted September 1, 2021 First time ever hearing that one. Curious now. Please post the plan. Link to comment Share on other sites More sharing options...
KingsOwn Posted September 1, 2021 Author Share Posted September 1, 2021 Here's the plan - I hope I've posted it correctly? In this plan if I place a new cabinet or edit size one of the existing cabinets in the kitchen the window in the wall that the cabinet is against is deleted. Thanks for your consideration. Mahakipawa 15.dwg Link to comment Share on other sites More sharing options...
MarkMc Posted September 1, 2021 Share Posted September 1, 2021 3 hours ago, KingsOwn said: Here's the plan - I hope I've posted it correctly? No, you exported it as a dwg file (CAD). To see the issue you have it needs to be a native Chief file, a plan file. With the plan file open use-File, Backup Entire Plan- check backup plan files only and send backup to zip. IF the resulting zip file is larger than 14 MBs you can't post it here. Then either place on cloud with a link or strip it down to the problem room(s). FWIW- when I've gotten weird things happen, that nobody else has seen yet, I've had them go away after either close and re-open Chief or better still after a full reboot. Hence they can not be reproduced. This is on Windows, we have no idea what OS you use? Link to comment Share on other sites More sharing options...
KingsOwn Posted September 1, 2021 Author Share Posted September 1, 2021 Thanks very much Mark, Zip file here. Mahakipawa-15.zip Link to comment Share on other sites More sharing options...
KingsOwn Posted September 1, 2021 Author Share Posted September 1, 2021 Sorry - forgot to say I'm using Windows 10. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 1, 2021 Share Posted September 1, 2021 Opened plan and cannot reproduce problem. Link to comment Share on other sites More sharing options...
KingsOwn Posted September 1, 2021 Author Share Posted September 1, 2021 Ghost in the machine? I just saved my file with a new name and the problem has gone away. Thanks a lot for everyone's attention - still don't know why that happened, but happy now it's gone. Link to comment Share on other sites More sharing options...
