lms_jam Posted July 5, 2021 Share Posted July 5, 2021 Hello fellow architects I have a new client that wants to build a Barndominium essentially a house inside of a metal building. I am familiar with the concept but I have never designed one. My questions are where would you start as far as the metal building is concerned. I would imagine that its much like the truss company they provide the plans and I just have an approximate idea until I see them. I'm wondering if any of you have some input would a metal building mf provide me some basics as far as size of straight columns and beams. and approx. placement. Also my client was wanting a 4" concrete pad and 5 or 6 for the garage I think he is hoping to save some money. I told him the concrete will have to be engineered for the structure but that probably all of it will have to be 5" thick. The building is 104' long and 38' wide including porches with a 5:12 roof slope. My other question is how tall to the eves should the side wall be if my interior celling height is 9'. I do have the beams catalogue downloaded from chief. Any input would so much appreciated Thanks Landry 3 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 5, 2021 Share Posted July 5, 2021 1. You can't call yourself an Architect unless you are licensed as such. 2. If you don't fully understand the structure you are proposing then you should seek the services of a Structural Engineer. 2 2 1 Link to comment Share on other sites More sharing options...
glennw Posted July 5, 2021 Share Posted July 5, 2021 1 hour ago, lms_jam said: The building is 104" long and 38" wide including porches That's a very small building! 1 hour ago, lms_jam said: with a 12:4 roof slope. And a very steep roof! 1 Link to comment Share on other sites More sharing options...
lms_jam Posted July 6, 2021 Author Share Posted July 6, 2021 10 minutes ago, glennw said: That's a very small building! And a very steep roof! Sorry meant 104' and 38' with a 5:12 roof I live in snow country 1 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted July 6, 2021 Share Posted July 6, 2021 Although I am not an Architect I did graduate from an Architecture school and was taught structural design by one of the preeminent experts in the field at the time (he designed the St. Louis Arch structural plans). I will impart all the knowledge that he passed on to my class. "Deeper, Cheaper, Better". I hope this helps. Pratt '89 3 Link to comment Share on other sites More sharing options...
BiggPopppaChief Posted July 11, 2021 Share Posted July 11, 2021 If it is a pole barn structure, the building will be supported by columns which will have their own pier support, the interior concrete slab is structurally independent of the building load so barring any high point loads on the slab from machinery or interior structure ( ie: car lifts, mezzanine columns etc.) a 4" slab would be sufficient although it would have to haunched at the exterior walls and possibly at interior wall locations as well if first floor ceiling will be a load bearing surface (2nd floor, storage attic etc.) However there are multiple variations of metal buildings so there is a lot of unanswered questions here. Not to mention your use of the term Barndominium seems like a play on condominium which would entail a multi-family residence and specific requirements for fire separation between units among other things. Be aware that fire-stopping becomes a very intricate issue in the situation you describe. The eave height is dependent on the desired interior height, the length of the overhang and the slope of the roof which all work together to determine the final T.O.P. height. 2 Link to comment Share on other sites More sharing options...
javatom Posted July 11, 2021 Share Posted July 11, 2021 A residential floor load on a bearing wall needs a footing with continuous rebar. A 4" slab is NOT going to work for this purpose. 1 1 Link to comment Share on other sites More sharing options...
BiggPopppaChief Posted July 11, 2021 Share Posted July 11, 2021 It was my understanding that it was to be a metal building in which case the exterior "skin" hangs from girts supported by the columns which have their own pier foundation, in that case there is no exterior load bearing "wall" as all the load transfers to the columns. Considering a minimum compressive strength of 2500 lbs/sqft a 4" concrete floor laid on a properly prepared compacted gravel base would far exceed the code minimums for floors which is less than 100 lbs/sqft in a worst case scenario. However increasing the slab thickness with an integral footer or "haunch" at interior walls, especially if they will be more than one story in height, would be recommended. And because the perimeter walls would not be carrying any roof load they would technically be interior walls as well. The 5" slab at garage locations would only be recommended for cases where commercial grade trucks, equipment or large RV's would be parked in the space. When I have built fire halls the pumper trucks weigh a ridiculous amount with full water tanks and we only use 6" slabs in those cases. Please in the future fully read and comprehend the issues before downgrading someones posts. 2 Link to comment Share on other sites More sharing options...
lms_jam Posted July 12, 2021 Author Share Posted July 12, 2021 Hello I'm sorry I've been sick the past week. Thanks for the responses I am working on a budget and I guess at the moment I'm just looking for exterior wall thickness. I thought maybe there was a standard size for x size building. The structure will be straight column and will sit on a concrete slab foundation with piers. I know that the structure and foundation will have to engineered taking into consideration the soil etc. My client doesn't have a building site or a MF for the metal building yet. He just wants something that he can show the city building inspector and the metal building MF and some other people so he can start getting a cost idea. Not the way I would go about things but to each his own. Link to comment Share on other sites More sharing options...
lms_jam Posted July 12, 2021 Author Share Posted July 12, 2021 8 hours ago, BiggPopppaChief said: If it is a pole barn structure, the building will be supported by columns which will have their own pier support, the interior concrete slab is structurally independent of the building load so barring any high point loads on the slab from machinery or interior structure ( ie: car lifts, mezzanine columns etc.) a 4" slab would be sufficient although it would have to haunched at the exterior walls and possibly at interior wall locations as well if first floor ceiling will be a load bearing surface (2nd floor, storage attic etc.) However there are multiple variations of metal buildings so there is a lot of unanswered questions here. Not to mention your use of the term Barndominium seems like a play on condominium which would entail a multi-family residence and specific requirements for fire separation between units among other things. Be aware that fire-stopping becomes a very intricate issue in the situation you describe. The eave height is dependent on the desired interior height, the length of the overhang and the slope of the roof which all work together to determine the final T.O.P. height. Yes it will be two residences separated by the garage. 1 Link to comment Share on other sites More sharing options...
javatom Posted July 12, 2021 Share Posted July 12, 2021 A slab supporting a wall is not entirely about the compressive strength. It is about the lack of a footing. A slab on grade could become subject to frost heave. The OP is from Eagar AZ. The elevation is 7000' so it might be an issue for the project. I would hate to be trying to defend the choice of eliminating footings at some point in the future but then again, anyone that wants to live in a pole barn probably doesn't really care. Link to comment Share on other sites More sharing options...
joey_martin Posted July 13, 2021 Share Posted July 13, 2021 Pole barns and shipping containers.....gee, thanks HGTV.. 2 Link to comment Share on other sites More sharing options...
Alchemyjim Posted July 16, 2021 Share Posted July 16, 2021 Here is one I did recently in Northern California. (No Snow Load) The steel building manufacturer said you can have X amount of windows, doors and skylights. As long as they do not interfere with any of our support beams you can place them where ever you want. I took the plan they provided and created a chief model with the steel framing in place. Then I added a 2x6 interior wall just inside the steel structure for the living area (do this by adding a 2x6 interior wall with a 2" air gap to the exterior wall). I do not recommend trying to wedge in 2x framing between the horizontal steel girts at 16" o.c. Not only is it a pain and labor intensive but having a traditionally framed wall allows for the elect, plumb, mech. to go smother, it also creates a barrier between the steel siding and the insulation. That is always a traditioned condensing point. You lose some square feet but that is a huge building. Basically find a steel building contractor that is a factory rep. They will give you plans to start from. Then go from there. Good luck. 4 2 Link to comment Share on other sites More sharing options...
betito Posted August 2, 2024 Share Posted August 2, 2024 sounds like an exciting project with the barndominium steel structure. For those grappling with the intricacies of building, remember that proper planning and design are crucial. Ensuring you have the right structural support and considering insulation options can make a big difference in your project's success. Have any of you tackled similar projects? Any tips on the best approaches for integrating steel structures with living spaces? Would love to hear your experiences and advice! 1 Link to comment Share on other sites More sharing options...
basketballman Posted August 2, 2024 Share Posted August 2, 2024 2 hours ago, betito said: sounds like an exciting project with the barndominium steel structure. For those grappling with the intricacies of building, remember that proper planning and design are crucial. Ensuring you have the right structural support and considering insulation options can make a big difference in your project's success. Have any of you tackled similar projects? Any tips on the best approaches for integrating steel structures with living spaces? Would love to hear your experiences and advice! Sounds ver A.I. ish to me Link to comment Share on other sites More sharing options...
Joemanderson01 Posted February 18, 2025 Share Posted February 18, 2025 On 7/5/2021 at 5:19 PM, Joe_Carrick said: 1. You can't call yourself an Architect unless you are licensed as such. 2. If you don't fully understand the structure you are proposing then you should seek the services of a Structural Engineer. WOW, just wow, could you have been any ruder Joseph P. Carrick? That was super uncalled for. Were here to help each other. If you cannot do better than this, please just don't say anything. Good day sir. BTW I've been with chief since they were on floppies,CD's and using a Pen Plotter. Your point? Intel(R) Xeon(R) Platinum 8173M CPU @ 2.00GHz 2.00 GHz (Dual processors) 192 GB 10TD 3ea Quadro P5000 6ea 24" HP Z Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 18, 2025 Share Posted February 18, 2025 1 hour ago, Joemanderson01 said: WOW, just wow, could you have been any ruder Joseph P. Carrick? That was super uncalled for. Were here to help each other. It wasn't intended to be rude. Architects are licensed by the States as professionals. Being a self taught draftsman does not qualify. My comment was totally valid and was intended to keep the OP from getting in trouble. 3 Link to comment Share on other sites More sharing options...
Gawdzira Posted February 18, 2025 Share Posted February 18, 2025 He had me at "Good day sir". I am happy to agree to disagree on almost anything if there is an effective use of "Good day sir!" Link to comment Share on other sites More sharing options...
ChiefUserGerald Posted May 7, 2025 Share Posted May 7, 2025 Hello All I have been following this tread for some time. I currently design residential structures, additions and interior remodel. I was recently asked to design a barndominium and after several attempts and following here I am stumped. is there anyone who has cad items that they offer. I saw different items but cannot edit them into my project. I am currently using X16. White Resiidence.dwg Link to comment Share on other sites More sharing options...
Geyatautsilvsgi Posted June 7, 2025 Share Posted June 7, 2025 Well, at the risk of folly, I will weigh in as well. This subject is being made far too complicated. I have designed numerous barndo's and honestly there are basically two methods to go by.The first method is if you are designing with an open concept design with large ceiling/roof spans and a slab foundation. This is if you are designing with traditional framing. Get an engineer to take care of the foundation, the span loads, and any point loads, whether ext or int. Then apply the sheet metal siding and all other sheet metal trimming. This makes the construction fairly simple but still give you the "barndo" look. The second and often most utilized is acquiring either a "pole barn" or metal building kit. Typically these will come with their own engineered plans from the manufacturer and thus no need to hire an outside engineer. Wall height is typically determined first when acquiring the package since the poles/steel framing is cut to length in the kit. It is in the finish work that will make the structure "homey" once the structure is complete.Since it is a typical commercial structure, the exterior walls will bear all the load and the interior can be completed however you like. Link to comment Share on other sites More sharing options...
