Having issues with different material\colours between Standard and PB Renders.
After setting the material and colour tones to an Alfresco BBQ area, found that I had two different colours to the brick pavings, ie in STANDARD RENDER the pavings
are a cream colour, which is required, but in PBR the pavings are grey.
Went to my User Group yesterday and no luck with them, see attached images of both renders, couldn't save the CA file as it's too large.
I am not a PBR expert by any means but take a look at your PBR ceiling.  There has been a greenish tone introduced in your PBR which may account for the pavers change in colour.   This is likely due to the outdoor background you are using.  I am not sure if you just need to change the background or make it white.  I am sure there are other discussions about this on the forum so I hope that at least sends you looking  in the right direction.  Hopefully that will fix the sheen you see in the stainless as well.
Chopsaw,
The ceilings are white, that was the first thing I checked.
The background is one of the CA "Backdrops" I have used, I did change this to white also, but nothing changed and
at the moment the "Backdrop" is Öpen Fields", that is why there is a bright green colouring reflected on to the stainless steel.
The back and left hand sides of the Alfresco are open so there is plenty of natural light coming in.
Try using the Rendering Technique Options to reduce the Hue slightly.  If not post your settings and an updated screen capture and maybe one of the "real" experts can chime in.
Chopsaw, been there done that as suggested, shifted Hue left and right accentuating green and red hues, pavings remain as is, grey in PBR beige in SR
Getting colours and textures to match between two different rendering techniques will be a challenge, the standard view uses a simplified lighting technique compared to PBR. A materials colour is the result of the material colour property settings and the properties of the light striking it and reflecting back to the observer. I think it would be best to decide on one or the other rendering techniques and adjust the material colour properties and light settings to achieve the desired look.
Graham, thanks for the feed back and understand where you are coming from, however I am happy to accept one or the other, but the PBR  would/should
be the priority as this is the ultimate format that I would show to clients, so I still don't understand why I can't get the the PBR to an acceptable colour range
and forgo any other variation to the SR.
Every time I made changes, the PBR made only very slight modifications to colour tones and basically the base colour still being grey was the dominant
colour, surely this is a glitch in the software and seeing that PBR is the premium format, how can I show clients a total different material colour that is different
on what is required, I can understand variation to colour tones between the two renders, but nor the base colour, ie dark grey versus cream.
Am i asking something that the software can't produce and if so, then this should be looked at by software engineers.
I've done a lot of PBR's and have not experienced the issue you describe. Without having your plan to see your settings it's difficult to determine what is going on. If you could post it I or someone else can check it out, I'm certain it can be resolved.
Graham, initially I tried to send the plan file but its size is too large ( 12MB ) so unless someone can give an alternative path, then I guess this will
end up as a stalemate, I have a presentation tomorrow, so I'll just have to talk my way around the software's deficiencies.
Thanks heaps for your input todate.
Regards Neil.
Neil,
I believe the upload limit for the forum is 25MB so there should not be an issue.  Be sure to save the plan file as a backup so that the materials are included and close it in Chief.
If it is larger than 25MB it can be put in a zip file or it can be uploaded to your cloud account and then just post the link here. I would be willing to look but Graham can likely provide a solution.
22 minutes ago, MarkMc said:
The upload limit changed to 2MB, at least that's what it said yesterday
That is quite helpful since an empty template file is almost 3MB ??
Maybe CA is trying to get out of the server business. Requiring a link to a file vs. the file attached is probably less taxing on their system. Just guessing of course.
Logged into to support and got the back-up procedure and:-
1.File size too large, Max size allowed is 2MB per file
2.The Back-Up file was saved in WinRAR, which I don't have a license, can this be done at CA's end.
I think your issue is lighting.... or a lack of it....try placing a few lights in there.... As PBR reflects real time lighting conditions, I think you actually have a big shadow in the area (see the opening to the left as a hint)....and the program needs light sources over such a large covered al fresco to create the right colours...
Just  a thought...
John,
It doesn't really matter how much light you give the area as I have done several attempts on doing this, the base colour is still grey only much lighter whereas
the actual pavings are a creamy/brown tones which are obvious in the SR render.
Here is a STD view and PBR view on a project I ran the other day. As you can see the colours are fairly close between the two views. However you will see for example that the white on the ceiling and the white on the cabinetry is slightly different, this is as would be expected as when PBR'ing the light processing is more complex and things like colour casting will be taken into account.
STD View
PBR View
I still say it's lighting.  Something is not right, and it's possibly in your standard view.
Check the room classification you've selected, rendering technique options for 3D are at default, whether you've got use backdrop selected and see what happens.  Also what is the actual floor brick you're using/can you screenshot the floor plan layout at this area showing all lighting.
Fellas, looking at Johns images above, this actually confirms the issues that I have talking about.
The above floor finishes have the same base colour with some variation in the PBR showing different tones and reflections according to
the light types and direction, which is exactly what I would be expecting.
I was going to send two more images, but when I looked at these the tones are somewhat similar, which is in stark contrast to the computer
images I did when adding ceiling lighting/camera settings. This is a common problem when trying to compare colours and tonings  generated
across computer, picture and printed material.
I do know, when playing with colours in "Twin Motion" , I get are far better colour representation.
Thanks heaps for all the input todate.
My apologies but I'm having some difficulty in understanding what you are saying here. The two posted pics demonstrate that colours are depicted fairly accurately between the STD camera and the PBR camera. The caveat here is that lighting and material properties need to be properly set, which often involves more than just dropping in a few default lights. Personally, if your ultimate goal is to produce a decent PBR then all of your adjustments need to be done in the PBR camera view, once it looks the way you wish then it's most likely that if you change the camera type to STD view then things will look proper. STD view is too basic and making your changes in STD view will likely result in poor or unexpected PBR results.
    29506
    Berretta969mm
    Berretta969mm
