JonathanWilliams Posted April 16, 2021 Share Posted April 16, 2021 I can not figure out how to fix a few voids in my exterior walls. I know they come from my raising the roof planes up 16" to create energy heel trusses and then manually editing the roof planes back down at areas which are not over conditioned living areas: the front porch and the garage. I've tried re-building/re-framing the walls and the roofs but the gaps will not disappear. I can convert the images to CAD and edit out the lines but I'd like to use the perspective drawings without the problems. Any advice would be appreciated. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 16, 2021 Share Posted April 16, 2021 yes I have also seen this and not sure why it's happening, please send it in to tech support. Link to comment Share on other sites More sharing options...
robdyck Posted April 16, 2021 Share Posted April 16, 2021 18 minutes ago, JonathanWilliams said: Dealt with this hundreds of times. A p-solid is the simplest. Elevation view, draw it on the wall, size and shape it (accurately so it blends), replicate it back 1", paint it, place it on 'material region' layer. 1 Link to comment Share on other sites More sharing options...
joey_martin Posted April 16, 2021 Share Posted April 16, 2021 Is floor framing layer turned on? Link to comment Share on other sites More sharing options...
JonathanWilliams Posted April 16, 2021 Author Share Posted April 16, 2021 16 minutes ago, solver said: Happens all the time. Sometimes an easy fix, sometimes not. It helps to have your plan file to work with -- saves lots of back and fourth. Close Chief and attach for the best help. Plan attached. I deleted some content to get it under 25 MB. Thanks for taking a look. BL72 PlanA CURRENT 2.11.21 GREAT RM 3.22.21 COPY 4.16.21.plan Link to comment Share on other sites More sharing options...
joey_martin Posted April 16, 2021 Share Posted April 16, 2021 You have a gap there because the ceiling in the garage is higher than the roof plane and there is no structure filling that spot. Link to comment Share on other sites More sharing options...
JonathanWilliams Posted April 16, 2021 Author Share Posted April 16, 2021 5 hours ago, joey_martin said: You have a gap there because the ceiling in the garage is higher than the roof plane and there is no structure filling that spot. Thank you. I'll try to figure out what I did wrong. Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 17, 2021 Share Posted April 17, 2021 1 hour ago, JonathanWilliams said: Thank you. I'll try to figure out what I did wrong. You did nothing wrong. There is no fix. Chief just blows up in these situations. I always have it especially above a garage because I like to lower my garage roof so there isn’t too much wall height above the garage door and the roof. (looks ugly) I really wish this would get fixed someday. As Robdyck said, psolid to the rescue. Link to comment Share on other sites More sharing options...
joey_martin Posted April 17, 2021 Share Posted April 17, 2021 You can actually place a small wall there, and call it an attic wall so that it doesn't show on the floor plan. Either way works, and whichever is fastest for you to work it out. Link to comment Share on other sites More sharing options...
joey_martin Posted April 17, 2021 Share Posted April 17, 2021 Link to comment Share on other sites More sharing options...
gelbuilding Posted April 17, 2021 Share Posted April 17, 2021 Hi Joey, nice one though, I cannot replicate what you did Link to comment Share on other sites More sharing options...
SNestor Posted April 17, 2021 Share Posted April 17, 2021 41 minutes ago, gelbuilding said: Hi Joey, nice one though, I cannot replicate what you did Put a wall like Joey said under the wall above...and place it on a layer you can turn off. Then...pull your roof up against the wall above...it's about an inch away. You should also create a Saved Plan View just to see your "roof plan". It'll make you work much easier... Link to comment Share on other sites More sharing options...
gelbuilding Posted April 17, 2021 Share Posted April 17, 2021 Thanks, Steve I see Joey has the wall drawn on level one and highlighted it as an attic wall. Though didn't work for me. If I change to attic wall the wall extends to the right. Link to comment Share on other sites More sharing options...
SNestor Posted April 17, 2021 Share Posted April 17, 2021 23 minutes ago, gelbuilding said: Thanks, Steve I see Joey has the wall drawn on level one and highlighted it as an attic wall. Though didn't work for me. If I change to attic wall the wall extends to the right. Just draw a wall, put it on the attic layer...or any layer that you can turn off. Don't make it an "attic wall". You might start by pulling the roof to the wall above...that might be most of the problem... Link to comment Share on other sites More sharing options...
gelbuilding Posted April 17, 2021 Share Posted April 17, 2021 Thanks, Steve got it. How about the gap in the facia? i.e between the roof tiles and eaves? Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 17, 2021 Share Posted April 17, 2021 If I were Chief I would be embarrassed that this is what my customers have to do to solve this problem. It’s ridiculous, X12 going on X13 and it’s still contortionist p-solids and hidden wall bandages. Link to comment Share on other sites More sharing options...
robdyck Posted April 18, 2021 Share Posted April 18, 2021 19 hours ago, Michael_Gia said: If I were Chief I would be embarrassed that this is what my customers have to do to solve this problem. It’s ridiculous, X12 going on X13 and it’s still contortionist p-solids and hidden wall bandages. What's wrong with having to cut individual pieces of siding or drywall or smear on some stucco just to cover up the holes? Don't you have a tool trailer beside your desk like I do? And don't forget to wear a helmet! 1 Link to comment Share on other sites More sharing options...
