robdyck Posted March 22, 2021 Share Posted March 22, 2021 Does anyone know if Chief can show a patio door like the one shown in the image? And if so...how? Chief always puts the opening unit in the middle And if you use a 2 / 1 combination, you can't specify the opening unit all the way to one side. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 22, 2021 Share Posted March 22, 2021 In the Options Panel of the dbx set the left to 3 and the right to 0 - or - right to 3 and left to 0 Chief will show 2 of the panels as sliding. Note that Chief will by default show the "Inside Panels" as sliding - but you can reverse the "swing" to make it the outside panels. Link to comment Share on other sites More sharing options...
robdyck Posted March 23, 2021 Author Share Posted March 23, 2021 On 3/22/2021 at 9:21 PM, Joe_Carrick said: Chief will show 2 of the panels as sliding. Expand Thanks Joe, but I need to show 2 as fixed, and 1 opening...left or right, but not middle. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 23, 2021 Share Posted March 23, 2021 On 3/23/2021 at 11:18 AM, robdyck said: Thanks Joe, but I need to show 2 as fixed, and 1 opening...left or right, but not middle. Expand Make a 2 panel next to a single fixed and mull them. Like this Link to comment Share on other sites More sharing options...
joey_martin Posted March 23, 2021 Share Posted March 23, 2021 @Dermot this is another one of those situations where Chief misses the boat. @robdyck will you place a suggestion for this situation please. This is one that should be fixed asap. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 23, 2021 Share Posted March 23, 2021 Mull to fixed is the way they're bought and built, so just do it. Think about it. For an OXX, the rightmost X is a fixed in its own frame. Look at the standard size charts from the big name manufacturers. Link to comment Share on other sites More sharing options...
robdyck Posted March 23, 2021 Author Share Posted March 23, 2021 On 3/23/2021 at 1:48 PM, GeneDavis said: Mull to fixed is the way they're bought and built, so just do it. Expand Not here. Or maybe you researched manufacturers in Western Canada:) So in our region, many mfrs have developed a system (to provide an affordable alternative to Nana Wall) where multiple panels are positioned within a single frame. The fixed panels are adjacent to and connected to each other and the frame with an interlocking seal...no mullions. The image I originally posted is actually from a tech manual. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 24, 2021 Share Posted March 24, 2021 Sounds like what I'm looking at in my Florida house right now. Three panels each on rollers, open it and the connecting slides allow stacking. I'm thinking these are generally warm climate products, and most are aluminum-framed. But I was talking about the brands like Andersen, Pella, Marvin, Lincoln, Windsor. Hope you wrote up a suggestion for Chief to ponder, and it ought to include images. Link to comment Share on other sites More sharing options...
MoeGia Posted March 24, 2021 Share Posted March 24, 2021 Marvin makes a stacking door in wood/clad frames. One end panel swings out, the rest can be unlocked and slide back to a stack, or pivot to stack at the end. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 24, 2021 Share Posted March 24, 2021 It's obvious that there are a lot of different configurations available today from various manufacturers. For CA to program all possible cases would be IMO unreasonable. For those cases that are not available as automatic options in Chief we can use combinations of doors an mull them to create what we need. Yes, it's more work for us but once we've done it ..... It can be saved in the Library for future use. IMO that's the kind of thing I get paid for and I just don't think it's reasonable to expect CA to program every special condition. Link to comment Share on other sites More sharing options...
robdyck Posted March 24, 2021 Author Share Posted March 24, 2021 On 3/24/2021 at 12:45 PM, Joe_Carrick said: IMO that's the kind of thing I get paid for and I just don't think it's reasonable to expect CA to program every special condition Expand I completely agree with this Joe, but dangit it's difficult to make the door I wanted! I thought it'd be easy to use 3 separate door panels with no jamb or casing, and a separate doorway with the jamb and casing, then mull them. But it's too difficult to control the door panel inset so that the 2 fixed panels are, let's say centered on the main layer, and the opening panel is to the exterior of those panels. Link to comment Share on other sites More sharing options...
robdyck Posted March 24, 2021 Author Share Posted March 24, 2021 Ok, close enough, right? I just can't open this door for certain view types...and I still get Chief's gorgeous sill! And don't get me started on the jamb material issues. Why can a window have separate materials for the frame and trim, but not a door for the jamb and trim (unless you spec a molding)?? Link to comment Share on other sites More sharing options...
robdyck Posted March 24, 2021 Author Share Posted March 24, 2021 And GEEEEEEEEZ. Materials!! Easy enough to place 3 panels and make your own door symbol, but if you want proper material control for inside vs outside you pretty much need to build every piece like you're in the factory! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 24, 2021 Share Posted March 24, 2021 Rob, You don't really need the "Doorway". You can specify the casings, etc for the "Mulled Unit" Link to comment Share on other sites More sharing options...
robdyck Posted March 24, 2021 Author Share Posted March 24, 2021 On 3/24/2021 at 1:33 PM, Joe_Carrick said: Rob, You don't really need the "Doorway". You can specify the casings, etc for the "Mulled Unit" Expand Yeah...about that...to get my panel offset, I used 2 panels with no jamb or casing, and 1 "fixed" panel that's recessed. Then when you mull them, the casing is recessed, and if you unselect that...it pulls the opening unit away from the others. That's why I made a symbol from the 3 panels. Link to comment Share on other sites More sharing options...
robdyck Posted March 24, 2021 Author Share Posted March 24, 2021 And take a look at what you get in plan view with this symbol. I quit!! 3-PANEL PATIO DOOR.calibzFetching info... Link to comment Share on other sites More sharing options...
GeneDavis Posted March 24, 2021 Share Posted March 24, 2021 There are two classes of doors mentioned in this thread, both of which Chief should address with mods. Stacking multi-slides are what Rob is needing. Almost all in market are aluminum, and almost all are warm-clime doors. Fold-in and stack. Often referred to with the NanaWall brand. Cost as much as a car. Just as we got barn doors from Chief, we should get these. Good 2-d representation, and in 3-d, options to show open or closed, and for open, how much open. Who's done proper requests for these? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 24, 2021 Share Posted March 24, 2021 Gene, Have you tried using multi-panel bifold doors. For me they work fine to represent the "Fold and Stack" either inside or outside. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 24, 2021 Share Posted March 24, 2021 Joe, I haven't and I will. Here is JeldWen's page for stacking multi-slide, and note those that pocket. https://www.jeld-wen.com/en-us/products/patio-doors/browse?style=Multi-Sliding Link to comment Share on other sites More sharing options...
