DenisonDrywall 0 Posted January 29 Is there anything in the libray that would resemble a tapered, structural steel column/beam as you would find in a pre-engineered metal building? Or how do I create them? What about girts? Thanks, Share this post Link to post Share on other sites
Chopsaw 676 Posted January 29 If you want them represented in 3D they will need to be built with p-solids. You really only need to build one though as you can convert to as symbol or block and copy. It looks like you already have all the cad snaps you need so it should be fairly straight forward drawn in elevation view. Share this post Link to post Share on other sites
DenisonDrywall 0 Posted January 29 i can make them in p solids but how do you get them to taper? i've never figured out how to angle something like that. Share this post Link to post Share on other sites
Chopsaw 676 Posted January 29 Web and flanges will be separate but can then be merged if necessary. All drawn in elevation just like your screen shot. Or are they tapered the other way ? Share this post Link to post Share on other sites
solver 1672 Posted January 29 Quickly done demo. 1 2 Share this post Link to post Share on other sites
DenisonDrywall 0 Posted January 29 i drew them all separate so that in plan they look like a w-shape, but the one side goes vertically (z axis) and the other side tapers on the z axis. how do i get the one side to taper, but not the other? then for the beams, both sides taper/angle at different angles (roof on one side) Share this post Link to post Share on other sites
DenisonDrywall 0 Posted January 29 That video is exactly what I am needing! Thanks!! Share this post Link to post Share on other sites
Rpadge 37 Posted January 29 Doesnt help you right now, but I believe X13 will have the ability to create girts. Share this post Link to post Share on other sites
robdyck 510 Posted January 29 3 hours ago, DenisonDrywall said: What about girts? Depending on what will be used and how accurate it needs to be, you can simply use a general framing member set to a c-channel to represent the girts. The first one you use can be set to its own layer, adjust its schedule settings, material, and then copy and/or transform replicate as needed. You can do a whole building quite quickly this way. Share this post Link to post Share on other sites
DenisonDrywall 0 Posted February 1 I have taken two channel beams to make a z-girt and when I resize it, keeping it to porportion, the width changes but not the height. it says its changed but when you view it, its still the same, original height. it would work if it would be porpotional... should i be using a different method for girts? Share this post Link to post Share on other sites
joey_martin 397 Posted February 1 You are probably changing the bounding box and not the actual symbol. What are your steps? 1 Share this post Link to post Share on other sites
Alaskan_Son 2599 Posted February 1 1 minute ago, joey_martin said: You are probably changing the bounding box and not the actual symbol. What are your steps? Yep. My guess too. Need to Open Object and adjust Height/Width/Depth there...NOT Open Symbol (where we can only adjust how that symbol is treated when resized. Share this post Link to post Share on other sites
DenisonDrywall 0 Posted February 1 i opened Object (the door not the pencil w/ chair) and changed size there. i ended up drawing a line in the shape of a z and turned it into a 3-d molding polyline with the c- channel shape and it seems to be working better than the two channel beams put together. Share this post Link to post Share on other sites
Alaskan_Son 2599 Posted February 1 1 minute ago, DenisonDrywall said: i opened Object (the door not the pencil w/ chair) and changed size there. It sounds like perhaps your Stretch Planes were messed up then. Share this post Link to post Share on other sites
DenisonDrywall 0 Posted February 1 i think the symbol is messed up. Share this post Link to post Share on other sites
