HumbleChief Posted October 12, 2020 Share Posted October 12, 2020 Been working on this longer than I care to admit but cannot get the elevation, which of course is the only thing I need. to look OK. Different steps and gaps that I can't seem to repair. Thank you in advance. ELEVATION NIGHTMARE 1.plan Link to comment Share on other sites More sharing options...
Rpadge Posted October 12, 2020 Share Posted October 12, 2020 I am sure there are others that may have a better solution, but I changed the wall definition slightly for the thicker stucco wall, that seems to help. 1 Link to comment Share on other sites More sharing options...
DzinEye Posted October 12, 2020 Share Posted October 12, 2020 You just need to move the stucco to the outside layer on your thick wall... then line up the walls 1279498644_ELEVATIONNIGHTMARE1_X1.plan 1 Link to comment Share on other sites More sharing options...
rgardner Posted October 12, 2020 Share Posted October 12, 2020 Combination of problems that worked for me to fix it: 1.) the outside room is undefined, set it as a balcony 2.) your 1st floor wall has been manually adjusted settings tab default top and bottom, 3.) the walls are not lined up at the right layer 4.) the inside room is not defined 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted October 12, 2020 Author Share Posted October 12, 2020 THANK YOU!! It was the 1" stucco layer that I had added to the main layer instead of a new 1" exterior layer. So helpful and very much appreciated. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 12, 2020 Share Posted October 12, 2020 Haven't you guys ever heard of the "Edit Layout Lines" tool on views sent to a layout while on layout? DJP Link to comment Share on other sites More sharing options...
SNestor Posted October 12, 2020 Share Posted October 12, 2020 1 hour ago, HumbleChief said: THANK YOU!! It was the 1" stucco layer that I had added to the main layer instead of a new 1" exterior layer. So helpful and very much appreciated. Yep...it's the way you had the wall definition for the 13.5" thick wall. Link to comment Share on other sites More sharing options...
