MIKESU Posted March 7, 2014 Share Posted March 7, 2014 Having trouble importing a dwg format plan from customer into chief v10.08, os=xp pro. When trying to import, I get a warning, dwg library error, invalid dwg version. Any help would be great Mike S Link to comment Share on other sites More sharing options...
Kiwideziner Posted March 7, 2014 Share Posted March 7, 2014 FOR 10.08 you would need the Acrap drawing in something like version 2000i, its too long ago to remember exactly. The problem you are having is the dwg is being supplied in a later format than CA10.08 will handle. cheers Link to comment Share on other sites More sharing options...
Bill_Emery Posted March 7, 2014 Share Posted March 7, 2014 Download Autodesks free True View 2014, and you can save the DWG back to earlier versions. It will go back as far as 2000. 1 Link to comment Share on other sites More sharing options...
DesignBuildBrian Posted June 3, 2015 Share Posted June 3, 2015 What version of auto cad opens the best in chief? Link to comment Share on other sites More sharing options...
tommy1 Posted June 3, 2015 Share Posted June 3, 2015 Mike, if you like and if you don't have it fixed yet, send the dwg to me via my email below. I'll send it back. Link to comment Share on other sites More sharing options...
Dave13 Posted June 4, 2015 Share Posted June 4, 2015 If your client has AutoCad have them save the drawing as R14 (.dwg file type) or R12 (.dwx file type) and you should be able to import the file. After your client saves it as a older version tell them not to open it or it will convert back to their version again which it sounds like is newer than your version of Chief. Chief and Autocad do not seem to be backward compatible, meaning you can not open a newer version of the software than the version you have. Link to comment Share on other sites More sharing options...
lbuttery Posted June 4, 2015 Share Posted June 4, 2015 Autocad is backward compatible Lew Link to comment Share on other sites More sharing options...
dshall Posted June 4, 2015 Share Posted June 4, 2015 Autocad is backward compatible Lew I am not sure about that. I have exported a dxf file in v14 and I had to redo to v12 (or whatever the version numbers are) because he was working with an older version of acad. Link to comment Share on other sites More sharing options...
Dave13 Posted June 4, 2015 Share Posted June 4, 2015 Both my surveyors use earlier versions of AutoCad than I use and neither one of them can open my files. If you know how to do it Lou please let me know, I get tired of converting the files all the time. Link to comment Share on other sites More sharing options...
yusuf-333 Posted June 4, 2015 Share Posted June 4, 2015 Both my surveyors use earlier versions of AutoCad than I use and neither one of them can open my files. If you know how to do it Lou please let me know, I get tired of converting the files all the time. You must export it in to thier version or earlier and send it without opening in your PC. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 4, 2015 Share Posted June 4, 2015 DraftSight is free and will save to these formats. Link to comment Share on other sites More sharing options...
