winterdd Posted August 28, 2020 Share Posted August 28, 2020 i built decking for the porch and run the stemwall to the underside of the rimjoist? what are the strips so i can remove them? Link to comment Share on other sites More sharing options...
javatom Posted August 28, 2020 Share Posted August 28, 2020 It could be a sill plate. Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 29, 2020 Share Posted August 29, 2020 In a camera view, left-click-select the object and in the Edit Toolbar, open its dialog box to find out what it is. DJP Link to comment Share on other sites More sharing options...
winterdd Posted August 29, 2020 Author Share Posted August 29, 2020 it won't let me left click. doesn't recognize it. Link to comment Share on other sites More sharing options...
rgardner Posted August 29, 2020 Share Posted August 29, 2020 32 minutes ago, ChiefUserBigRob said: it won't let me left click. doesn't recognize it. Try using the temporary hide tool to get to it. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted August 29, 2020 Share Posted August 29, 2020 Post a plan if you didn't figure-it-out yet. Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 29, 2020 Share Posted August 29, 2020 look at the floor structure of that balcony/room. You probably have an extra material there you might've added by mistake. Try making the floor structure one thick material to see if that's the problem. If it's not part of the floor then it might be the ceiling below. Link to comment Share on other sites More sharing options...
DzinEye Posted August 29, 2020 Share Posted August 29, 2020 To me the question is deeper than what is that strip of brown... It looks to me like you have a white painted pressure treated lumber with a sill plate below it. I don't think you're wanting to have white painted pressure treated lumber exposed there either are you? My guess is you'd rather have either the brick come all the way up to just under the porch finish, or the same shiplap siding you have on the rest of the house, no? The issue may be with the wall definition you used to create that 'room' if you want to see siding. Link to comment Share on other sites More sharing options...
winterdd Posted August 29, 2020 Author Share Posted August 29, 2020 yeah, i painted the rim joist. that strip looks like a moulding but it isn't. Link to comment Share on other sites More sharing options...
