room labels
ChiefuserMathews
If you use walls inside the basement walls, like we would to finish a basement, there seems to be a bug that will find a "room" between the 2"x wall the and the basement wall. Annoying as hell!! Select the interior 2"x wall and mark as no room definition and see if that extra "room" goes away.
I have had this happen when redesigning an as built plan.  All rooms are defined, then some walls get demolished, and new walls added.  Not every time, but sometimes a second room label will appear.  I just delete the unwanted labels, seems to work ok, but it can be confusing as to what label belongs to what room.
This is what I do. Usually a short wall in the mechanical room.
