BeachHouse1 Posted June 26, 2020 Share Posted June 26, 2020 Been holding off talking about this. I've been able to adapt to the changes from AutoCad Architecture fairly well so far. With one major exception. The drag the cursor work flow. This method has some serious shortcomings. I know you can right click when making walls and this allows you to click a point and then click another point. This is good, but you can't start out with a right click. The biggest problem is when you need to zoom in on one thing select it and then zoom in on another. This is extremely difficult when dragging. What have some of you done to work around this, or is there a setting somewhere to changes it? Thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted June 26, 2020 Share Posted June 26, 2020 Occasionally I do find myself scrolling in an awkward way with my middle finger but as you get more experience you will get used to selection and zoom settings even thought they are not all perfectly intuitive. Link to comment Share on other sites More sharing options...
parkwest Posted June 26, 2020 Share Posted June 26, 2020 Using a 3Dconnexion space mouse will take care of your problem. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 26, 2020 Share Posted June 26, 2020 I agree, I’ve suggested that Chief provide us a quick method to switch to click-release-click but so far we’re stuck using a few goofy workarounds. My currently preferred method is: 1. Click and drag to start operation 2. Shift+Z (Zoom) during drag 3. Press either Center Mouse Wheel (Pan) or optionally the Escape key 4. Pan and zoom as desired (NOTE: If you’re panning anyway, which you likely are if you’re employing the trick, then the step above isn't even necessary) 5. Click again to finish You can customize your hotkeys to make the operation pretty easy but for me, the OOB ones actually work just fine. Anyway, it’s not as easy as it could be, but it’s something. Link to comment Share on other sites More sharing options...
DzinEye Posted June 26, 2020 Share Posted June 26, 2020 This has come up before. I think most recently in this suggestion which you might give your +1 to if you like the idea: ALSO: In addition to Michael's suggestions above you can get a very helpful extra powerful zoom speed from your mouse wheel by holding down the Ctrl key while using the scroll wheel. Props to Rene Rabbitt for sharing that tip a ways back. Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 26, 2020 Share Posted June 26, 2020 *shocked that Michael doesn't have a 3d mouse. Now I know what to get him for xmas- ****This video WILL cause seizures**** 200626 13-46-21.mp4Fetching info... Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 26, 2020 Share Posted June 26, 2020 On 6/26/2020 at 4:21 PM, BeachHouse1 said: Been holding off talking about this. I've been able to adapt to the changes from AutoCad Architecture fairly well so far. With one major exception. The drag the cursor work flow. This method has some serious shortcomings. I know you can right click when making walls and this allows you to click a point and then click another point. This is good, but you can't start out with a right click. The biggest problem is when you need to zoom in on one thing select it and then zoom in on another. This is extremely difficult when dragging. What have some of you done to work around this, or is there a setting somewhere to changes it? Thanks Expand Aside from us goofing around, it may be news to you that you can change selection modes in your preferences or by adding the 3 selection modes to your toolbars. Selection modes coupled with the Marquee Select Similar tool makes it so that I never need to zoom in to select what I want to. Not to mention deselection tricks, @Alaskan_Son favorite thing to talk about Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 26, 2020 Share Posted June 26, 2020 On 6/26/2020 at 9:03 PM, Renerabbitt said: Not to mention deselection tricks, @Alaskan_Son favorite thing to talk about Expand ...... I was having such a nice day..... 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted June 26, 2020 Share Posted June 26, 2020 On 6/26/2020 at 4:58 PM, parkwest said: Using a 3Dconnexion space mouse will take care of your problem. Expand I'm with David on this one too.. No dragging, shifting..just pull the knob up and move.. Its a great tool. Link to comment Share on other sites More sharing options...
BeachHouse1 Posted June 26, 2020 Author Share Posted June 26, 2020 I have alternate buttons on my mouse. I have been practicing using a thumb button. I expect I will get better at it. Truly, so far I like the work flow in Chief better than the work flow in AutoCad Architecture. Link to comment Share on other sites More sharing options...
JKEdmo Posted October 19, 2022 Share Posted October 19, 2022 Good morning, This is a reply to an old topic, but I was unsure if there was ever any conclusion. I have to agree with the original post about how awkward it is to hold down the mouse button and zoom with the scroll wheel at the same time. (In my case, I really notice it when doing CAD polylines). Is there a setting that allows "click release" behavior, or is that counter to Chief's method? I use a trackball, so I wonder if that makes things more difficult. Thanks again, Jim Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 19, 2022 Share Posted October 19, 2022 On 10/19/2022 at 6:04 PM, JKEdmo said: This is a reply to an old topic, but I was unsure if there was ever any conclusion. Expand Yes. Chief doesn't work this way and they have yet to provide any setting that allows us to do so. The best replacement option that I know of continues to be the method I mentioned earlier in the thread: On 6/26/2020 at 5:09 PM, Alaskan_Son said: 1. Click and drag to start operation 2. Shift+Z (Zoom) during drag 3. Press either Center Mouse Wheel (Pan) or optionally the Escape key 4. Pan and zoom as desired (NOTE: If you’re panning anyway, which you likely are if you’re employing the trick, then the step above isn't even necessary) 5. Click again to finish Expand Again, you can customize your hotkeys if desired to make the operation easier, but the basics are the same. Link to comment Share on other sites More sharing options...
JKEdmo Posted October 19, 2022 Share Posted October 19, 2022 On 10/19/2022 at 6:33 PM, Alaskan_Son said: Yes. Chief doesn't work this way and they have yet to provide any setting that allows us to do so. The best replacement option that I know of continues to be the method I mentioned earlier in the thread: On 6/26/2020 at 5:09 PM, Alaskan_Son said: 1. Click and drag to start operation 2. Shift+Z (Zoom) during drag 3. Press either Center Mouse Wheel (Pan) or optionally the Escape key 4. Pan and zoom as desired (NOTE: If you’re panning anyway, which you likely are if you’re employing the trick, then the step above isn't even necessary) 5. Click again to finish Expand Expand Hey, thanks for the quick reply. I'll take a closer look at your answer in detail. Being new to the software, I have a lot of questions, especially relative to the software I come from. But, I will try to adapt! Jim Link to comment Share on other sites More sharing options...
