SteveNovato Posted June 19, 2020 Share Posted June 19, 2020 I am trying to integrate a 'room' schedule into my plans so there is not so much clutter. If I generate a window schedule, the window label is automatically inserted on the plan. When I do the same for a 'room' schedule the room schedule label does not show on the plan. I do have 'use callout for label' checked. I also restarted the computer with no change in behavior. Maybe this is the intended behavior for a room schedule?? Hopefully one of the many experts on this site can point me in the right direction. Thanks in advance... Steve Existing house plan.plan Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 19, 2020 Share Posted June 19, 2020 you do have to tell Chief to include the room in the schedule. Open the rooms DBX and tell it to include in the schedule. Link to comment Share on other sites More sharing options...
SteveNovato Posted June 19, 2020 Author Share Posted June 19, 2020 Thanks Perry...I will give it a try. Link to comment Share on other sites More sharing options...
Dermot Posted June 19, 2020 Share Posted June 19, 2020 Rooms do not currently have the ability to automatically display a schedule callout instead of the normal room label. You could use a manual solution like turning off the room labels and placing your own callouts or using a note schedule instead. If you want the program to work differently, then I would encourage you to make an actual feature request. To make a feature request, you should make a post on the suggestions forum here: https://chieftalk.chiefarchitect.com/forum/8-suggestions/ Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 19, 2020 Share Posted June 19, 2020 I was talking about a room finish schedule, which I use for a room schedule Link to comment Share on other sites More sharing options...
SteveNovato Posted June 19, 2020 Author Share Posted June 19, 2020 I am also using a room finish schedule, but only including dimensions and area. Link to comment Share on other sites More sharing options...
robdyck Posted June 19, 2020 Share Posted June 19, 2020 I'd suggest turning off all the extra layers that can be included in a room label except for ROOM LABELS so that the name only display in plan view. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 23, 2020 Share Posted June 23, 2020 As Dermot mentioned, there are various methods, but one of the easiest for your example is to just create a callout like this.... ....and then copy/paste it into all your rooms. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 23, 2020 Share Posted June 23, 2020 I'm using a custom Note Schedule to create a more comprehensive Room Schedule. Link to comment Share on other sites More sharing options...
