pinehawker Posted June 17, 2020 Share Posted June 17, 2020 I am drawing a commercial interior and the building has full size coolers. Once I place them along an exterior wall I need to enclose them in a wall that goes from top of cooler to ceiling. Any help would be appreciated. Also anywhere that I can find regular metal wall shelving. i am using x11 premier thank you Link to comment Share on other sites More sharing options...
DzinEye Posted June 17, 2020 Share Posted June 17, 2020 Picture or graphic of some sort would help, but I think you can just build walls the size of your coolers and put in a door 'opening' the size you need to fit the cooler in. Link to comment Share on other sites More sharing options...
Chrisb222 Posted June 17, 2020 Share Posted June 17, 2020 Drag bottom of wall up. Link to comment Share on other sites More sharing options...
rlackore Posted June 17, 2020 Share Posted June 17, 2020 Could you use a soffit? Link to comment Share on other sites More sharing options...
pinehawker Posted June 17, 2020 Author Share Posted June 17, 2020 That would be perfect I have several walls ie 30ft long with coolers o them and need to have a wall or soffit on top running the whole length. Could u tell me how you did that. Sorry I’m very new to this program. Link to comment Share on other sites More sharing options...
lbuttery Posted June 17, 2020 Share Posted June 17, 2020 Chris: dragging walls up or down is not recommended and should only be done if necessary and when you have the skill to do so otherwise, the plan can become "messy" there are many other methods for enclosing a fridge Lew 1 Link to comment Share on other sites More sharing options...
pinehawker Posted June 17, 2020 Author Share Posted June 17, 2020 Maybe I’m lost here but when I am drawing in working plan view I’m looking down on the interior how do I get to where I can add or adjust on the straight on view to adjust the walls Link to comment Share on other sites More sharing options...
rlackore Posted June 17, 2020 Share Posted June 17, 2020 2 hours ago, pinehawker said: That would be perfect I have several walls ie 30ft long with coolers o them and need to have a wall or soffit on top running the whole length. Could u tell me how you did that. Sorry I’m very new to this program. Link to comment Share on other sites More sharing options...
joey_martin Posted June 17, 2020 Share Posted June 17, 2020 Just make a doorway in the wall for the coolers to slide into. That way you can control the framing and headers. Link to comment Share on other sites More sharing options...
pinehawker Posted June 17, 2020 Author Share Posted June 17, 2020 Awesome thank you all for the help on the top wall. Played around and got it looking as I need. Now I need to find wall shelving. Is there a free form for that or does it come from a catalog Link to comment Share on other sites More sharing options...
rlackore Posted June 18, 2020 Share Posted June 18, 2020 For quick-and-dirty shelving, you can use Chief's Shelf tool. Here's a stainless steel shelf I use for my commercial kitchen and restaurant work: Advance Tabco Wall Shelf X11.calibz Advance Tabco Wall Shelf X12.calibz Link to comment Share on other sites More sharing options...
SNestor Posted June 18, 2020 Share Posted June 18, 2020 On 6/17/2020 at 9:30 AM, pinehawker said: Maybe I’m lost here but when I am drawing in working plan view I’m looking down on the interior how do I get to where I can add or adjust on the straight on view to adjust the walls Wall height is controlled by the “ROOM” specification. Link to comment Share on other sites More sharing options...
pinehawker Posted June 18, 2020 Author Share Posted June 18, 2020 rlackore, thank you that will due for what i need. Link to comment Share on other sites More sharing options...
pinehawker Posted June 18, 2020 Author Share Posted June 18, 2020 do you ever loose the cursor on the plan. I have noticed at times i loose the cursor and have to restart to get it back. Link to comment Share on other sites More sharing options...
