HumbleChief Posted May 20, 2020 Share Posted May 20, 2020 Anyone else seen this behavior? Occasional. Random? Dunno what causes it but seems like switching plan view cures it. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted May 20, 2020 Share Posted May 20, 2020 Yes Larry, I have had similar experiences like that. Even today after placing several area lights in my plan I could not select them by just clicking on them, had to do as you were doing by dragging a selection box over the area light symbol to get it selected. Strange as the light source layer is active and not locked and tabbing did not work either. Link to comment Share on other sites More sharing options...
robdyck Posted May 20, 2020 Share Posted May 20, 2020 This behavior is common when toggling between different plan views. Chief gets bunged up and can't remember what plan view is being used for what, and then starts to apply the settings from one plan view to another. To resolve that issue: from the project browser, just double click the plan view you wish to use, even if its already open, and that will reset it. Chief has other issues with plan views holding their settings. I'm sure other users have noticed that a plan view may 'jump' to a different default setting when something is imported into the plan using a layer that might not be on in that view. 2 Link to comment Share on other sites More sharing options...
DzinEye Posted May 20, 2020 Share Posted May 20, 2020 17 minutes ago, robdyck said: To resolve that issue: from the project browser, just double click the plan view you wish to use, even if its already open, and that will reset it. What?!!... jeesh. I've always resorted to restarting my computer. Glad to know there's an easier way. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted May 20, 2020 Share Posted May 20, 2020 32 minutes ago, robdyck said: This behavior is common when toggling between different plan views. Chief gets bunged up and can't remember what plan view is being used for what, and then starts to apply the settings from one plan view to another. To resolve that issue: from the project browser, just double click the plan view you wish to use, even if its already open, and that will reset it. Chief has other issues with plan views holding their settings. I'm sure other users have noticed that a plan view may 'jump' to a different default setting when something is imported into the plan using a layer that might not be on in that view. Thanks for the tip. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 20, 2020 Share Posted May 20, 2020 This same thing happens to me also, Larry. Like you, I can't reproduce it and don't know what causes it. When it happens it usually won't allow me to select certain objects but will select objects, like roof planes, that are on an "off" layer. Strange, but happens. I have been closing and restarting also but will try Robert's "fix" next time. Link to comment Share on other sites More sharing options...
HumbleChief Posted May 20, 2020 Author Share Posted May 20, 2020 1 hour ago, TheKitchenAbode said: Thanks for the tip. 1 hour ago, robdyck said: This behavior is common when toggling between different plan views. Chief gets bunged up and can't remember what plan view is being used for what, and then starts to apply the settings from one plan view to another. To resolve that issue: from the project browser, just double click the plan view you wish to use, even if its already open, and that will reset it. Chief has other issues with plan views holding their settings. I'm sure other users have noticed that a plan view may 'jump' to a different default setting when something is imported into the plan using a layer that might not be on in that view. I'll try that as well next time. THANKS Link to comment Share on other sites More sharing options...
HumbleChief Posted May 20, 2020 Author Share Posted May 20, 2020 2 hours ago, TheKitchenAbode said: Yes Larry, I have had similar experiences like that. Even today after placing several area lights in my plan I could not select them by just clicking on them, had to do as you were doing by dragging a selection box over the area light symbol to get it selected. Strange as the light source layer is active and not locked and tabbing did not work either. Yeah those are notorious in my plan sets as well. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 21, 2020 Share Posted May 21, 2020 I noticed you have an unusual amount of plan views open at the same time, you could try and close most of them and see if that helps. Link to comment Share on other sites More sharing options...
