HDbyJustin Posted April 12, 2020 Share Posted April 12, 2020 Hey everybody. I am learning a lot in Chief Premier x12 and I am amazed I didn't make this switch sooner. I have a question regarding resizing the 2d symbols for electrical plan. They seem small but I am not 100% sure how to adjust it. Link to comment Share on other sites More sharing options...
HDbyJustin Posted April 12, 2020 Author Share Posted April 12, 2020 I am, but all of the electrical symbols appear to be small. For example the smoke detector 2d symbol, the door chime 2d symbol. Link to comment Share on other sites More sharing options...
ShaneK Posted April 12, 2020 Share Posted April 12, 2020 Change scale of drawing, it is 3d object so it is to scale. Link to comment Share on other sites More sharing options...
joey_martin Posted April 12, 2020 Share Posted April 12, 2020 Unless you are asking for a specific reason, the out of the box Chief symbols are all I have used since v.9.5...not X9, version 9. They print just fine at 1/4" scale. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted April 13, 2020 Share Posted April 13, 2020 Double click the Smoke Detector symbol and change its size in the dbx. I do it all the time for the reasons you state. I use 12 and maintain aspect ratio. Would love to be able to set this as the default size but not show how or if it can be done. Interesting, I added the larger size to my library, changed the name from Chief's default 'Smoke Detector 1' to simply smoke detector and it's the first thing that comes up in the library when searching foe smoke detector. Nice. Off to change the CO detector as well. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 13, 2020 Share Posted April 13, 2020 5 minutes ago, HumbleChief said: Would love to be able to set this as the default size but not show how or if it can be done Like a lot of things it can be done, if you deem it important enough: You do this in your Profile.plan (make your edits and changes) assigning the edited symbols as defaults, then, thereafter your changes will be "Default" DJP Link to comment Share on other sites More sharing options...
HumbleChief Posted April 13, 2020 Share Posted April 13, 2020 1 minute ago, DavidJPotter said: Like a lot of things it can be done, if you deem it important enough: You do this in your Profile.plan (make your edits and changes) assigning the edited symbols as defaults, then, thereafter your changes will be "Default" DJP So simple right? Amazing how long I'll stick with a flawed method just because it's familiar.. Thanks David. Link to comment Share on other sites More sharing options...
Dermot Posted April 13, 2020 Share Posted April 13, 2020 Just to clarify some things... What you will need to do depends on whether or not you want to modify the 2D display for plan views versus the size of the actual symbol that appears in camera views, or both. If you want to modify both, then the task is pretty easy. Basically all you need to do is open the electrical object's specification dialog and adjust the size as shown in Larry's picture above. If you want to modify just the 2D cad block or the 3D geometry only, you will need to do this using the open symbol tool. The Symbol Specification dialog allows you to replace either the cad block for 2D display or the 3D geometry used in camera views. You will need to create the cad block or 3d geometry ahead of time to replace them. One way to modify the cad block is to use the Cad Block Management dialog to find the current cad block, use the insert tool to place it into a plan, modify it as needed, reblock it and give it a name you will recognize. You will then be able to choose this block from the Symbol Specification dialog. If this is an electrical object that you plan on reusing, then you should probably save it to the library. If this is an electrical object that you would like to use as a default for your electrical tools (such as an outlet, switch or light), then you should open the Electrical Defaults dialog and assign it as one of the appropriate defaults. More information about all of this can be found in the manual and training videos. 2 Link to comment Share on other sites More sharing options...
