parkwest Posted March 27, 2020 Share Posted March 27, 2020 Question: Can we get a curved wall to "follow stairs" of a flaired section of stairs? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 27, 2020 Share Posted March 27, 2020 Just like any other wall set to Follow Stairs, it has to be on top of the stairs, but yes, it works. Link to comment Share on other sites More sharing options...
parkwest Posted March 27, 2020 Author Share Posted March 27, 2020 Thank you Michael. Could you clarify what you mean with wall on top of stairs? Link to comment Share on other sites More sharing options...
LevisL Posted March 27, 2020 Share Posted March 27, 2020 David, I think you're running into a situation similar to one I just ran into the other day. I had a short section of half wall at the bottom of a staircase set to 'follow stairs', but it wouldn't slope for me either. I submitted it to tech support and was told: "As for the lower railing, it appears that in order for it to slope you need it to be two treads in length (closer to 2.5 treads in length)". Link to comment Share on other sites More sharing options...
parkwest Posted March 27, 2020 Author Share Posted March 27, 2020 28 minutes ago, LevisL said: David, I think you're running into a situation similar to one I just ran into the other day. I had a short section of half wall at the bottom of a staircase set to 'follow stairs', but it wouldn't slope for me either. I submitted it to tech support and was told: "As for the lower railing, it appears that in order for it to slope you need it to be two treads in length (closer to 2.5 treads in length)". Something isn't working then if Chief is saying it needs to be at least 2 treads in length because the half-wall I am working with is 5 treads. I'll send it in to tech support and see what they say about this one... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 27, 2020 Share Posted March 27, 2020 1 hour ago, parkwest said: Thank you Michael. Could you clarify what you mean with wall on top of stairs? Never mind. Looks like you're trying to do something a little different than I thought. Link to comment Share on other sites More sharing options...
SNestor Posted March 27, 2020 Share Posted March 27, 2020 1 hour ago, Alaskan_Son said: Just like any other wall set to Follow Stairs, it has to be on top of the stairs, but yes, it works. Not all walls...you can define a pony wall as a "railing"...and set it to "follow stairs". see attached... But, for the OP's question Michael is correct...but, I can't seem to get it to work. Chief...please start from scratch and make the stair tool so superior that we don't ever need to post another "issue with stairs"... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 27, 2020 Share Posted March 27, 2020 1 minute ago, SNestor said: Not all walls...you can define a pony wall as a "railing"...and set it to "follow stairs". see attached... You are correct. I was assuming it was just a standard railing....thus my "never mind". Doesn't look like those pony walls work quite the same. It would be a lot easier of people would just post plans. Link to comment Share on other sites More sharing options...
SNestor Posted March 27, 2020 Share Posted March 27, 2020 "It would be a lot easier of people would just post plans. " Yes it would. Link to comment Share on other sites More sharing options...
LevisL Posted March 27, 2020 Share Posted March 27, 2020 21 minutes ago, parkwest said: Something isn't working then if Chief is saying it needs to be at least 2 treads in length because the half-wall I am working with is 5 treads. I'll send it in to tech support and see what they say about this one... Sorry, I looked at your renderings too quickly! It looked like the pony wall was only up to the second tread, but I see now that's because it's hidden behind since it's not sloping the way you want! Let us know what tech. support says. Link to comment Share on other sites More sharing options...
parkwest Posted March 28, 2020 Author Share Posted March 28, 2020 Here is the just the plan file... not sure if this will work or not. I tried sending a zipped file but this page said it was over the size limit. It is not working! Thanks for all the suggestions Link to comment Share on other sites More sharing options...
DzinEye Posted March 28, 2020 Share Posted March 28, 2020 Like this? Link to comment Share on other sites More sharing options...
parkwest Posted March 28, 2020 Author Share Posted March 28, 2020 48 minutes ago, DzinEye said: Like this? Can it be a partial half height/railing pony wall connected to a full height wall? I would appreciate it if you could post your setting for this wall. Thank you. Link to comment Share on other sites More sharing options...
DzinEye Posted March 28, 2020 Share Posted March 28, 2020 1 hour ago, parkwest said: I would appreciate it if you could post your setting for this wall. Thank you. It probably qualifies as a workaround, but it works... I just used the new X12 ability to do a custom stringer. Set the width to match your wall thickness and I made it extra deep (30" below the tread) because it was the only way to make it look right on the curve. Set it for whatever height above the tread you want, and of course you can do whatever you want with the railing. 2 Link to comment Share on other sites More sharing options...
DzinEye Posted March 28, 2020 Share Posted March 28, 2020 You will probably need to break your stair and only apply this to the lower part of your stairs Link to comment Share on other sites More sharing options...
SNestor Posted March 28, 2020 Share Posted March 28, 2020 52 minutes ago, DzinEye said: It probably qualifies as a workaround, but it works... I just used the new X12 ability to do a custom stringer. Set the width to match your wall thickness and I made it extra deep (30" below the tread) because it was the only way to make it look right on the curve. Set it for whatever height above the tread you want, and of course you can do whatever you want with the railing. Now that is a creative solution...excellent. With Chief's stair tool...you gotta think outside the box...way outside. 1 Link to comment Share on other sites More sharing options...
parkwest Posted March 30, 2020 Author Share Posted March 30, 2020 For those who are interested, it looks like the flared stairs needs some more work from the programmers. Here is what I was told: - Support Answer - Katherine Kory Monday, Mar 30, 2020 - 06:44 AM PDT Hello David, Thank you for contacting Technical Support Services. I took a look at your plan and it appears that it is the flared portion of the stairs that is causing those railings to not follow the stairs. I drew a set of straight stairs and the pony wall railing followed the stairs but as soon as I flared those stairs it stopped working. I understand this is not ideal for you, but you might do a set of straight stairs to get as much of the stairs railings to follow the stairs, then use polyline solids (as an example) to make the flared portion. The railing still wouldn't follow the stairs, but it'd get you closer than you currently are. I will be passing this along to our development department to look at further for a future version of the software. I hope this information is helpful. Best regards, Katherine Technical Support Analyst Chief Architect Link to comment Share on other sites More sharing options...
robdyck Posted March 30, 2020 Share Posted March 30, 2020 My workaround...Make your flared stairs. Use a second stair for the railing beside the flared stairs (You can change a straight stair to an arc). Draw a curved wall under the curved stair used for railing. This is my 30 second example. Another couple of minutes would really clean things up. 1 1 Link to comment Share on other sites More sharing options...
parkwest Posted March 30, 2020 Author Share Posted March 30, 2020 Good work, Robert! Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 31, 2020 Share Posted March 31, 2020 Nice 30 sec solution, Robert. Link to comment Share on other sites More sharing options...
