dskogg Posted March 25, 2020 Share Posted March 25, 2020 HI all you smart people, anyone have a symbol or can suggest how best to build a sink cabinet like this? Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 25, 2020 Share Posted March 25, 2020 On 3/25/2020 at 7:35 PM, dskogg said: HI all you smart people, anyone have a symbol or can suggest how best to build a sink cabinet like this? Expand Solid tools or if you dont want to model it, take a look in the kohler cat Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 25, 2020 Share Posted March 25, 2020 I cannot clearly see what the sink looks like but you can do that, to a degree with just a base cabinet and its dialog box: place the base cabinet, place your chosen sink in it and then remove the "Toe Kick", then set the countertop at the height from the floor you wish and then manually raise up the bottom to whatever height above the floor you wish, it is rather straight forward. DJP Link to comment Share on other sites More sharing options...
robdyck Posted March 25, 2020 Share Posted March 25, 2020 On 3/25/2020 at 7:43 PM, DavidJPotter said: I cannot clearly see what the sink looks like but you can do that, to a degree with just a base cabinet and its dialog box: place the base cabinet, place your chosen sink in it and then remove the "Toe Kick", then set the countertop at the height from the floor you wish and then manually raise up the bottom to whatever height above the floor you wish, it is rather straight forward. DJP Expand I'll add that you can just increase the countertop thickness in the dbx and in plan view, right click your sink symbol to adjust it vertical offset. Should be pretty easy. Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2020 Author Share Posted March 25, 2020 On 3/25/2020 at 7:54 PM, robdyck said: I'll add that you can just increase the countertop thickness in the dbx and in plan view, right click your sink symbol to adjust it vertical offset. Should be pretty easy. Expand I guess i just need to find a sink that is square so it looks like it is integrated that is the challenge. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 25, 2020 Share Posted March 25, 2020 On 3/25/2020 at 7:59 PM, dskogg said: I guess i just need to find a sink that is square so it looks like it is integrated that is the challenge. Expand Keep in mind that your client is buying the sink they pick out at the fixture store and not the one in a virtual model. Just say'n DJP Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2020 Author Share Posted March 25, 2020 On 3/25/2020 at 8:04 PM, DavidJPotter said: Keep in mind that your client is buying the sink they pick out at the fixture store and not the one in a virtual model. Just say'n DJP Expand Actually david this is the entire unit that is available, sink and cabinet included, thus integrated sink. Link to comment Share on other sites More sharing options...
robdyck Posted March 25, 2020 Share Posted March 25, 2020 Kohler / Traverse. This sink symbol can be adjusted to do what you need. Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2020 Author Share Posted March 25, 2020 On 3/25/2020 at 8:14 PM, robdyck said: Kohler / Traverse. This sink symbol can be adjusted to do what you need. Expand Rob, i dont see any traverse in kohler? Another name? Link to comment Share on other sites More sharing options...
rgardner Posted March 25, 2020 Share Posted March 25, 2020 On 3/25/2020 at 9:47 PM, dskogg said: Rob, i dont see any traverse in kohler? Another name? Expand Just saw that yesterday it is in the pedestal sink section for Kohler Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2020 Author Share Posted March 25, 2020 On 3/25/2020 at 10:01 PM, rgardner said: Just saw that yesterday it is in the pedestal sink section for Kohler Expand Ryan, my kohler library does not have a pedestal section? Link to comment Share on other sites More sharing options...
rgardner Posted March 25, 2020 Share Posted March 25, 2020 On 3/25/2020 at 10:16 PM, dskogg said: Ryan, my kohler library does not have a pedestal section? Expand X12 yesterday I believe it was in bathrooms, sinks, pedestal sorry not at computer at the moment but it was definitely in it yesterday as I used it then replaced it with another one. Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2020 Author Share Posted March 25, 2020 still no luck, did a search for pedestal and traverse, no traverse. I might have found a sink that is close, not square corners though. Cheers. Link to comment Share on other sites More sharing options...
rgardner Posted March 25, 2020 Share Posted March 25, 2020 On 3/25/2020 at 10:23 PM, dskogg said: still no luck, did a search for pedestal and traverse, no traverse. I might have found a sink that is close, not square corners though. Cheers. Expand Sorry I went back through to my job yesterday and found it isn't traverse, it was tresham. But looking at it you may want a different one: Check this one out: Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2020 Author Share Posted March 25, 2020 On 3/25/2020 at 11:26 PM, MarkMc said: Rene gave the answer - since you want square corners it's easy. Adding radiused edges would take a bit longer. Psolid to size of sink, convert to solid, explode solid, delete top face. If you want a drain hole add a cylinder and extrude the bottom face a fraction so you can do boolean subtraction. OR easier add a small round psolid to the bottom. Convert to symbol, fixture interior, inserts into a countertop, sink. If you convert the whole counter and sink to a symbol then it's a PIA to use with a cabinet. Cabinet with counter top size you need, add the sink symbol, adjust it's height in relation to the counter if you didn't when making the symbol. Rebuild 3D. Making took about the same time it took to write all this. Certainly less time than the collective search. Integrated sink.planFetching info... Expand Yes, sometimes one cant see the forest for the trees...i was just making one, used a pop up drain and some solids. Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2020 Author Share Posted March 25, 2020 1 Link to comment Share on other sites More sharing options...
joey_martin Posted March 26, 2020 Share Posted March 26, 2020 On 3/25/2020 at 8:04 PM, DavidJPotter said: Keep in mind that your client is buying the sink they pick out at the fixture store and not the one in a virtual model. Just say'n Expand Unless I spec a specific model and style. Sometimes it matters. When I do a custom home I spec a lot of fixtures and finishes. No sense in letting someone else rack up those fees...that's what they come to me for. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 26, 2020 Share Posted March 26, 2020 On 3/26/2020 at 1:24 AM, joey_martin said: Unless I spec a specific model and style. Sometimes it matters. When I do a custom home I spec a lot of fixtures and finishes. No sense in letting someone else rack up those fees...that's what they come to me for. Expand A lot of the time my custom home and remodeling clients have not yet picked out specific fixtures for their design. If they have done so and supply me with specs, I then try my utmost to make my drawings as realistic as possible but in the end, it is the materials they specify and the fixtures and appliances that they personally pick out and or buy that is applied to their project. My drawings are conceptual, their project is what, in the end, counts and matters, not any virtual model. DJP 1 Link to comment Share on other sites More sharing options...
robdyck Posted March 26, 2020 Share Posted March 26, 2020 On 3/25/2020 at 9:47 PM, dskogg said: Rob, i dont see any traverse in kohler? Another name? Expand Glad to see you got your vanity complete. As far as the 'Traverse' sink goes...you should make sure your Kohler library is up to date. At any rate, you can see that by manipulating the stretch planes, you'd be able to make all the sink sizes from the 'Bliss' collection by Kube. Link to comment Share on other sites More sharing options...
dskogg Posted March 26, 2020 Author Share Posted March 26, 2020 On 3/26/2020 at 11:59 AM, robdyck said: Glad to see you got your vanity complete. As far as the 'Traverse' sink goes...you should make sure your Kohler library is up to date. At any rate, you can see that by manipulating the stretch planes, you'd be able to make all the sink sizes from the 'Bliss' collection by Kube. Expand Thanks Rob, it is a good quick option, thanks for that, only thing doesnt it make the sink deeper? I think the bliss sink top is about 4.75" thick. Link to comment Share on other sites More sharing options...
dskogg Posted March 26, 2020 Author Share Posted March 26, 2020 On 3/26/2020 at 9:56 AM, DavidJPotter said: A lot of the time my custom home and remodeling clients have not yet picked out specific fixtures for their design. If they have done so and supply me with specs, I then try my utmost to make my drawings as realistic as possible but in the end, it is the materials they specify and the fixtures and appliances that they personally pick out and or buy that is applied to their project. My drawings are conceptual, their project is what, in the end, counts and matters, not any virtual model. DJP Expand Yes that totally makes sense, in this case I am doing the design and renovation for this project and I am trying to provide a cost effective solution to the customer and at the same time selling him on the design. He is open to some more modern looks and I want to help with this and also build my design build portfolio, often times clients will make their own decisions without designer input and sometimes it doesn't work well in the end. So if you are only designing then you job stops their, but if you are also building then I want to help guide them to have the best most current look. Does this make more sense now? Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 26, 2020 Share Posted March 26, 2020 I whipped this one up real quick, maybe a bit nicer: RABS INTEGRATED SINK.calibzFetching info... It will cut the countertop flush and just paint it the same as the counter. Also you can play with this molding edge profile: RABS INTEGRATED SINK EDGE MOLDING.calibzFetching info... 1 Link to comment Share on other sites More sharing options...
