Why doesnt wc show rope lights?
dskogg
I made this LED mirror symbol with led lighting behind, it will only show in pbr not in wc , why is this?
Also i tried making a hole inside a circle sold and ca wont let this happen, Ie i made a circle turned it into a solid at 1/4" thick and then had a smaller circle i wanted to make a hole in the first solid and ca wont let this happen? I am trying to make a donut led light instead of just a circle led light.
Not sure about the rope light although they are different than regular lights.
There should not be an issue with the solids but you can do that just fine with psolids so it is not necessary to use solids.
Expand
That’s what I did, I made a circle 1” dia, turned it into a poly line solid 1/4” thick and then tried cutting a hole out of it.. would not let me do it.
  On 3/25/2020 at 12:03 AM, robdyck said:
the hole needs to be a p-solid before it can be a hole. Did you do that?
Expand
Actually, to be more precise, it just needs to be converted to an actual polyline.  A circle is not a polyline.  It can either be converted to a multi-segment polyline or to a couple arcs.  Converting to a polyline solid does the trick, not because its a polyline solid but because its a polyline.  During the convert process, it's just broken into 2 arcs automatically.  Semantics?  Maybe,,but I think it's good to understand whats actually happening.  You can get to the same end any number of ways.  No matter what you do though, a true CAD Circle object cannot be used with boolean operations.
Expand
When converting in x11 it used to ask if you want a a polling solid then you could make it a hole
now it doesn’t give you an option it gives you hole option
 I will post plan tomorrow
  On 3/25/2020 at 2:39 PM, robdyck said:
I think @dskogg was using the "solid hole" choice as opposed to the 'hole in polyline solid" option after choosing polyline solid.
Expand
HI Rob thanks for video, your polyline solid has no thickness, mine is .25" thick and when i do all those steps it does not allow me to make it a hole?
Expand
Yes, it has a thickness, the default thickness of 1". Your definitely doing something odd. Is the larger circle already a polyline solid? Can you post your plan?
  On 3/25/2020 at 6:59 PM, dskogg said:
Here is the plan, the round polyline solid below mirror i am trying to make the circle inside a mirror so the led looks like a donut and then
re insert it back into mirror above.
LED cube mirror.zipFetching info...
Expand
For the rope lights to show up in a WC renderings, they'll need to be much brighter. I'd suggest making a copy of the rope lights on their own layer for WC pics and use separate lighting  sets for WC. In the pic below, the rope light is at 2000 lumens.
Expand
Ok, that is really dumb, so in pbr it works but in wc you need to up lumens?
