SMC2992 Posted March 21, 2020 Share Posted March 21, 2020 Hi friends I want to draw a door to a strong room which has 2 single shutters, one opening inside of the room and second out side to the room. the wall is 12"thick. How i can achieve this? thanks Salahuddin Link to comment Share on other sites More sharing options...
GeneDavis Posted March 21, 2020 Share Posted March 21, 2020 Use the signature feature in your profile to tell us what software you use, and the system on which it is run. Otherwise, you won't get much help here. Link to comment Share on other sites More sharing options...
SMC2992 Posted March 21, 2020 Author Share Posted March 21, 2020 35 minutes ago, GeneDavis said: Use the signature feature in your profile to tell us what software you use, and the system on which it is run. Otherwise, you won't get much help here. ok updating Link to comment Share on other sites More sharing options...
Doug_N Posted March 21, 2020 Share Posted March 21, 2020 Ain't that the truth! lol Link to comment Share on other sites More sharing options...
SMC2992 Posted March 21, 2020 Author Share Posted March 21, 2020 Please check now Link to comment Share on other sites More sharing options...
SMC2992 Posted March 21, 2020 Author Share Posted March 21, 2020 12 minutes ago, SMC2992 said: ok updating Yes This is what i want, How to achieve this? Link to comment Share on other sites More sharing options...
SMC2992 Posted March 21, 2020 Author Share Posted March 21, 2020 9 minutes ago, Doug_N said: Ain't that the truth! lol Not like this I want like this Link to comment Share on other sites More sharing options...
robdyck Posted March 21, 2020 Share Posted March 21, 2020 2 hours ago, SMC2992 said: Hi friends I want to draw a door to a strong room which has 2 single shutters, one opening inside of the room and second out side to the room. the wall is 12"thick. How i can achieve this? thanks Salahuddin What are the components or layers of the 12" thick wall? Could you explain what you mean by the term 'shutters'? Link to comment Share on other sites More sharing options...
DougMaddox Posted March 21, 2020 Share Posted March 21, 2020 Salahuddin, Use two 6" thick walls with a room divider between. Then place a door in each wall, opening the way you want. Might be easiest to make one wall; add a room divider about two inches away; then add the second wall an inch away and then slide them together. Worked for me Link to comment Share on other sites More sharing options...
GeneDavis Posted March 21, 2020 Share Posted March 21, 2020 I didn't do a room divider between. I just made one of the walls "no room division." And presumed that all the OP wants is the 3D look. Link to comment Share on other sites More sharing options...
SMC2992 Posted March 22, 2020 Author Share Posted March 22, 2020 I have tried to and placed another door on other side and it worked. see the attached file, Hope i have done it in a right way. Thanks to All room.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted March 22, 2020 Share Posted March 22, 2020 You don't need two walls , Chief will allow one door to sit exactly on top of the other ( center tool works) and make it look like it is one door.... 1n both 2D and 3D Link to comment Share on other sites More sharing options...
SMC2992 Posted March 22, 2020 Author Share Posted March 22, 2020 22 minutes ago, Kbird1 said: You don't need two walls , Chief will allow one door to sit exactly on top of the other ( center tool works) and make it look like it is one door.... 1n both 2D and 3D Thank you so much Link to comment Share on other sites More sharing options...
