Door with 2 shutter
Hi friends
I want to draw a door to a strong room which has 2 single shutters, one opening inside of the room and second out side to the room. the wall is 12"thick.
How i can achieve this?
thanks
Salahuddin
35 minutes ago, GeneDavis said:
Use the signature feature in your profile to tell us what software you use, and the system on which it is run.
Otherwise, you won't get much help here.
ok
updating
2 hours ago, SMC2992 said:
Hi friends
thanks
Salahuddin
What are the components or layers of the 12" thick wall? Could you explain what you mean by the term 'shutters'?
Salahuddin,
Use two 6" thick walls with a room divider between.  Then place a door in each wall, opening the way you want.  Might be easiest to make one wall;  add a room divider about two inches away; then add the second wall an inch away and then slide them together.  Worked for me
You don't need two walls , Chief will allow one door to sit exactly on top of the other ( center tool works) and make it look like it is one door.... 1n both 2D and 3D
Thank you so much
    29799
    Rkey6936
    Rkey6936
  • Similar Content
    • By StructEng58
      Does anyone have the Andersen AEAHID6080 Entry Door for Chief?
      Thank you in advance,
      Chris Rood
    • By Ange822
      Hi there,
      I am using Chief Architect X9
      I can't seem to find a sidelite that is "half lite" only 3/4 lites or full lites.
      I'm wondering if theirs a way to customize an object to make the glass smaller?
      I have attached an image - this is the closest I could find. I tried looking on the 3D warehouse but had no luck.
      (Using the Simpson Door Company - Arlington Sidelight)
      Also - does anyone know if on the elevation view you can get rid of the door operation indicators only on the sidelites?
      thanks in advanced.
      Angela
    • By YoderW
      Is there any way to create a small gap or offset between the door and casing? Like a real door would have, to leave just a tiny bit of room for the hinges. Specifically for open interior doors. I've made a door hinge symbol I'd like to use, and I assume I'd have to make a different one for various swing angles, but I'm not seeing any obvious way to create that small gap. By default, Chief's doors just meet the casing at the corner completely, leaving no room. I could force the hinges in there, but they would clip through the door and casing and look less realistic.
      I'd also like to add a strike plate to the casing and latch to the door, but short of placing the symbols myself that doesn't seem very plausible right now. Maybe a suggestion for a future version of Chief.
    • By No1ZZTopfan
      Look very close and tell me if you can find the hidden bi-fold door. I'll post where its at in a few days. :-)
    • By stevenyhof
      I have downloaded the three garage door catalogs from the Library, and non of them have a standard wide paneled garage door. They also do not have a wide paneled 8' high door (5 panels high)
      What they have is 5 panel high flush doors - so this can be stretched - cool
      But there are no standard paneled, wide (16' and 18') 4 or 5 high garage doors.
      Does someone have access to such doors?
      The long panel door comes in both 4 panel wide and 2 panel wide - very good.
      The door with the 4 panels across come should also come with 8 panels for wider doors.
      Am I missing it somewhere? It's like the most common door used from Menards and Lowes. Starter doors.
      Thank you
