Richard_Morrison Posted March 6, 2020 Share Posted March 6, 2020 I'm looking for a board & batten texture (image) that has a smooth finish, rather than the rough finish that the Chief library has. White preferable, but maybe other pastel colors, too. Can anyone point me in the right direction? Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2020 Share Posted March 6, 2020 I made one for another user a little while back. It's a very specific size and spacing, but maybe you can use it. Paint it whatever color you like using "Blend", or take the normal map and use that with any color you like. I can also make you a custom texture if necessary. You can have this one though... B&B 1x2x16.calibzFetching info... 1 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 6, 2020 Author Share Posted March 6, 2020 Thanks, Michael! I'm on the lookout for one with a little more apparent depth for the battens. Something a little closer to: https://db-homes.com/home-building-options/siding-crane-premium-pointe-board-batten/ which I just came across. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 6, 2020 Share Posted March 6, 2020 On 3/6/2020 at 9:24 PM, Richard_Morrison said: Thanks, Michael! I'm on the lookout for one with a little more apparent depth for the battens. Something a little closer to: https://db-homes.com/home-building-options/siding-crane-premium-pointe-board-batten/ which I just came across. Expand Than import those textures as "Custom Materials" and you are then "Done!" DJP Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2020 Share Posted March 6, 2020 On 3/6/2020 at 9:24 PM, Richard_Morrison said: Thanks, Michael! I'm on the lookout for one with a little more apparent depth for the battens. Something a little closer to: https://db-homes.com/home-building-options/siding-crane-premium-pointe-board-batten/ which I just came across. Expand That depth is kinda limited by the behavior of those normal maps. I think you're unlikely to find any that are "deeper" than the one I attached. In order to get any more depth you end up needing to use an "angled" profile. One of the mapping gurus like @Renerabbitt, @Chiefer, or @gelbuilding can correct me if I'm wrong, but in my experience, it's just a limitation to the way those normal maps work. It's the reason I tend to do that kind of thing with actual 3D geometry. 1 Link to comment Share on other sites More sharing options...
robdyck Posted March 6, 2020 Share Posted March 6, 2020 CertainTeed and Mastic Home Exteriors both have vinyl board and batten textures. Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 6, 2020 Share Posted March 6, 2020 On 3/6/2020 at 9:31 PM, Alaskan_Son said: it's just a limitation to the way those normal maps work Expand Yup, much better results just using material regions IMO or my new fav, backsplash, as it can be added to style palettes. Easy to make a board and batten style palette and drop it on a backsplash to make your batten. Normals maps simply don't work well with two adjacent/inversed 90 degree angles. There is no way for it to illustrate that in 2d with some associated UV mapping. Better off creating the geomotry or it just looks like a rolled texture like the one mentioned by Rob..plus it's too difficult to make a bunch of different batten styles through textures 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted March 7, 2020 Share Posted March 7, 2020 You can also use an extra framing Layer, for Full-3D, been doing it that way for a few years now..... same for Rain Screen actually. M. https://chieftalk.chiefarchitect.com/topic/16852-board-and-batten-library/?tab=comments#comment-141647 Link to comment Share on other sites More sharing options...
Chiefer Posted March 7, 2020 Share Posted March 7, 2020 Comparison between normal map (left) and region/backsplash( right image) (don't mind the tint) Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 7, 2020 Author Share Posted March 7, 2020 On 3/7/2020 at 4:21 AM, Chiefer said: Comparison between normal map (left) and region/backsplash( right image) Expand The region/backsplash is far better, of course, and it looks like you have more control over the location of the battens. I confess that it's not clear to me how you get the battens, though. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 7, 2020 Share Posted March 7, 2020 On 3/7/2020 at 6:05 AM, Richard_Morrison said: The region/backsplash is far better, of course, and it looks like you have more control over the location of the battens. I confess that it's not clear to me how you get the battens, though. Expand Simply draw a single batten to the appropriate width and tall enough to cover your wall using the Material Region or backsplash tool. Then Multiple Copy across your wall at the desired spacing. Copy and Paste onto the next wall, adjust height as necessary, and repeat the Multiple Copy procedure. Just have to repeat the Multiple Copy for each unique plane. There are a few different siding types you can use this method for and you can either set the Material Region to Cut Finish Layers or not depending on the specifics, but for most B&B, not cutting finish layers is probably best. You just have to add corner boards manually unless you use the Material Region to cut the recesses instead of as the battens. If you're feeling brave and adventurous, you can also block your material region and add it to the library. Make it tall enough to cover your tallest walls and then you can use a Polyline Distribution Path to completely trace all your walls. Explode that path and all your material regions are distributed for you. 1 Link to comment Share on other sites More sharing options...
gelbuilding Posted March 7, 2020 Share Posted March 7, 2020 Hi Richard, See calibz file below Smooth board & batten.calibzFetching info... 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 7, 2020 Author Share Posted March 7, 2020 On 3/7/2020 at 7:26 AM, Alaskan_Son said: Simply draw a single batten to the appropriate width and tall enough to cover your wall using the Material Region or backsplash tool. Then Multiple Copy across your wall at the desired spacing. Copy and Paste onto the next wall, adjust height as necessary, and repeat the Multiple Copy procedure. Just have to repeat the Multiple Copy for each unique plane. There are a few different siding types you can use this method for and you can either set the Material Region to Cut Finish Layers or not depending on the specifics, but for most B&B, not cutting finish layers is probably best. You just have to add corner boards manually unless you use the Material Region to cut the recesses instead of as the battens. If you're feeling brave and adventurous, you can also block your material region and add it to the library. Make it tall enough to cover your tallest walls and then you can use a Polyline Distribution Path to completely trace all your walls. Explode that path and all your material regions are distributed for you. Expand Michael, Thanks for the detailed explanation. This works great! I don't seem to be able to get the Polyline Distribution Path to work, though. I save a batten as an object (it is listed as an architectural block) and looks like a tiny rectangular flagpole in the preview. Then I draw a distribution path and select that block. They shows up perfectly in plan, but in 3D (even with all layers turned on)... nothing except the first one. Exploding the path does nothing. Not sure what I'm missing there. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 7, 2020 Author Share Posted March 7, 2020 On 3/7/2020 at 10:20 AM, gelbuilding said: Hi Richard, See calibz file below Expand George, Thanks for this! This material looks great! If I wanted to modify these to get larger spacing between the batts, what would the process be like? Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 7, 2020 Author Share Posted March 7, 2020 On 3/7/2020 at 3:02 AM, Kbird1 said: You can also use an extra framing Layer, for Full-3D, been doing it that way for a few years now..... same for Rain Screen actually. M. https://chieftalk.chiefarchitect.com/topic/16852-board-and-batten-library/?tab=comments#comment-141647 Expand Mick, I did try your method, and I think that it's brilliant, especially if you need a materials list to include the battens and furring strips. Resizing and rotating battens is very easy, too. It gets a little messy with building framing so early in the process, though, because if you have to rebuild framing after you've done a bunch of adjustments to the battens, you lose all of your customizations. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 7, 2020 Share Posted March 7, 2020 On 3/7/2020 at 4:27 PM, Richard_Morrison said: Mick, I did try your method, and I think that it's brilliant, especially if you need a materials list to include the battens and furring strips. Resizing and rotating battens is very easy, too. It gets a little messy with building framing so early in the process, though, because if you have to rebuild framing after you've done a bunch of adjustments to the battens, you lose all of your customizations. Expand Like many CA Work arounds there are a few quirks indeed ...... Normally in the past I have done the "Battening" after the main Design Work so "customizations" and thus more work is minimised. Usually by just changing the Wall Definition from the non-battened Wall to the Battened Walltype and Framing it, and then "retaining Framing" after the Customizations like removing Doubles at openings are done. Have not tried it is X12 honestly , so I am not sure if all is the same , think I started using this back in X9 or maybe earlier and there maybe more Framing "options" now... M. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 7, 2020 Share Posted March 7, 2020 On 3/7/2020 at 3:59 PM, Richard_Morrison said: Michael, Thanks for the detailed explanation. This works great! I don't seem to be able to get the Polyline Distribution Path to work, though. I save a batten as an object (it is listed as an architectural block) and looks like a tiny rectangular flagpole in the preview. Then I draw a distribution path and select that block. They shows up perfectly in plan, but in 3D (even with all layers turned on)... nothing except the first one. Exploding the path does nothing. Not sure what I'm missing there. Expand Not sure either. Maybe you can post a quick example plan. I will say that Material Regions can get quirky if they're too much taller than your walls though. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 7, 2020 Share Posted March 7, 2020 Thanks for sharing @gelbuilding. That's not too shabby at all. Just a quick note though....I notice you named the texture"...inverted", but the Bump Map actually still needs to be inverted. It's current casting shadows the wrong way and appears more like strips of log veneer added to the surface. Nice texture though! Link to comment Share on other sites More sharing options...
gelbuilding Posted March 8, 2020 Share Posted March 8, 2020 On 3/7/2020 at 4:03 PM, Richard_Morrison said: George, Thanks for this! This material looks great! If I wanted to modify these to get larger spacing between the batts, what would the process be like? Expand Richard, Advise what your preference is and I can adjust the mat, See below I made another texture and you can see imperfections on the texture, dirt, and scratches. I don't like clean texture. For the board width, you need to increase the scale size of the texture in Chief. On 3/7/2020 at 7:35 PM, Alaskan_Son said: Thanks for sharing @gelbuilding. That's not too shabby at all. Just a quick note though....I notice you named the texture"...inverted", but the Bump Map actually still needs to be inverted. It's current casting shadows the wrong way and appears more like strips of log veneer added to the surface. Nice texture though! Expand See attached the new texture and let us know if the normal map is the correct way. I use so many programs and I'm always changing the normal map. Board & Battern.calibz Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 8, 2020 Share Posted March 8, 2020 On 3/8/2020 at 5:03 AM, gelbuilding said: See attached the new texture and let us know if the normal map is the correct way. I use so many programs and I'm always changing the normal map. Expand Thanks George. The one you attached previously using the bump map instead of a normal map was actually a little more realistic and I had already fixed it pretty easily. It just required inverting the bump map in Chief (just the little checkbox). I was just letting you know was all. Thanks again Link to comment Share on other sites More sharing options...
gelbuilding Posted March 8, 2020 Share Posted March 8, 2020 For memory I think I used a displacement map in the bump channel. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 11, 2020 Author Share Posted March 11, 2020 On 3/8/2020 at 5:03 AM, gelbuilding said: Richard, Advise what your preference is and I can adjust the mat, See below I made another texture and you can see imperfections on the texture, dirt, and scratches. Expand I really appreciate the offer, George, but I'm hoping to learn how to do this myself. Link to comment Share on other sites More sharing options...
gelbuilding Posted March 11, 2020 Share Posted March 11, 2020 I created this in substance designer. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 11, 2020 Author Share Posted March 11, 2020 On 3/11/2020 at 7:53 PM, gelbuilding said: I created this in substance designer. Expand Well, that's a little pricier than I was hoping for.... I may take you up on your offer. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 11, 2020 Share Posted March 11, 2020 On 3/11/2020 at 8:26 PM, Richard_Morrison said: Well, that's a little pricier than I was hoping for.... I may take you up on your offer. Expand Take a look here at Chief's Post on S.D. Link to comment Share on other sites More sharing options...
