dshall Posted October 11, 2014 Share Posted October 11, 2014 On 10/11/2014 at 12:20 AM, GerryT said: FYI I've made doz & doz suggestions in this area and I know others have as well -- not including all the threads in the forum's suggestion area. With my last inquiry, i was told by TS not to submit any more suggestions or to inquiry about extending RUBY as the the program was not designed to be extended into this area. Still scratching my head as to what a suggestion line is for? Bottom Line: if any one at Chief is interested -- you might check your circular archives. Yep, Gerry has been all over this like white on....... seriously, this is nothing new, there has been quite a few of us who have been looking for this stuff. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 11, 2014 Share Posted October 11, 2014 Lets keep it going and make it a hot topic, maybe someone will notice. Also p-line labels is needed. Link to comment Share on other sites More sharing options...
dshall Posted October 11, 2014 Share Posted October 11, 2014 On 10/11/2014 at 12:27 AM, DRAWZILLA said: .......Also p-line labels is needed. .... that is so huge, thanks for bringing it up again, not only PLINES but CLOSED PLINES. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 11, 2014 Share Posted October 11, 2014 On 10/10/2014 at 11:44 PM, KirkClemons said: Well, again, I've never heard anything. But your right there may be some prior requests. Just not enough to hit the radar and make it through the grapevine here in tech. Kirk, You should search the Forums (new and old) for "Ruby" & "Macros" & "Labels". If that's not enough, talk to Chris Tenbrink. Link to comment Share on other sites More sharing options...
Bill_Emery Posted October 11, 2014 Share Posted October 11, 2014 I have not previously noticed the change in window object properties. In X5 we had to work around to get a macro for header sizes. Headers are now part of the object_properties for windows. I view this as a positive step for continued implementation of Ruby. I've included a screen shot of X5 Object properties, and the only header information is header height. I must have missed the memo on this. Are there other areas where object_properties have been improved? Link to comment Share on other sites More sharing options...
KirkClemons Posted October 11, 2014 Share Posted October 11, 2014 Yes, I agree with all these. But I was referring specifically to Jared's initial request to convert the decimal output to mixed fraction. Which I'm hoping he was able to find a solution for based on Joe's and my input. As to all these other requests, maybe a new thread could be started under the suggestions forum to discuss how each of these could be implemented in a useful way. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 11, 2014 Share Posted October 11, 2014 Kirk, I think several of us have beat this drum to the point where CA should just compile what we've asked for and see how much could be done. To start another thread in the suggestions forum would IMNSHO be superfluous. Link to comment Share on other sites More sharing options...
GerryT Posted October 11, 2014 Share Posted October 11, 2014 To further confuse Jared: attached is a macro to display inch only. joe's method is a little better in that it rounds to the 1/16 " -- without that, you can get some weird fractions. To round to a different fraction change the 16 multiplier to another(8,4-- etc.) For my self - i like to see more participation first from Chief as all the support has been on the customer side to date and mostly ignored. header.zipFetching info... Link to comment Share on other sites More sharing options...
lbuttery Posted October 11, 2014 Share Posted October 11, 2014 i was told by TS not to submit any more suggestions or to inquiry about extending RUBY as the the program was not designed to be extended into this area Gerry: maybe TS meant - file it is as a suggestion and not as a TS query ??? the day CA cuts-off suggestions - is the day CA starts to die Lew Link to comment Share on other sites More sharing options...
GerryT Posted October 11, 2014 Share Posted October 11, 2014 Lew: Gray Area -- But the submittals considered "suggestions" were inquires as of why something did not not work properly in RUBY. At any rate I won't be posting on this topic anymore -- as there is no internal support for RUBY in Chief -- IMNOHO --- so any meaningful future expansion other than some token is doubtful. Link to comment Share on other sites More sharing options...
lbuttery Posted October 11, 2014 Share Posted October 11, 2014 Gerry: I agree as I think CA will continue with the label "concept" and not go anywhere near what is really needed Lew Link to comment Share on other sites More sharing options...
jbaehmer Posted October 11, 2014 Author Share Posted October 11, 2014 Wow - I leave work early on Friday and I come back this AM and see that I opened a can of worms. This is something I know we have asked often in the past. I am not a programmer so I don't know how complicated it can be to program it into the software. If anything it would be good to know that CA acknowledges they see what we are going for and if it can not be implemented for "xyz" reason to let us know and not leave us in limbo wondering why they haven't done it yet. I believe if we were given a reason why some features can't be implemented right now, most of us would understand. However, Let's keep this thread going to bring keep it in the front of their minds. I do want to say, that I do appreciate everyone at CA. They all work very hard. The creation of this software has changed my family's life in too many ways to count. This is only to try and bring a feature that I (and many others) believe will help productivity. Rant over Link to comment Share on other sites More sharing options...
jbaehmer Posted October 11, 2014 Author Share Posted October 11, 2014 On 10/11/2014 at 5:32 AM, GerryT said: To further confuse Jared: attached is a macro to display inch only. joe's method is a little better in that it rounds to the 1/16 " -- without that, you can get some weird fractions. To round to a different fraction change the 16 multiplier to another(8,4-- etc.) Appreciate it. I noticed that if it a whole number only, it shows up strange. Like if I put in a 9" header. Here is a pic of what I am seeing. Link to comment Share on other sites More sharing options...
GerryT Posted October 11, 2014 Share Posted October 11, 2014 OOPs header1.zipFetching info... Link to comment Share on other sites More sharing options...
jbaehmer Posted October 11, 2014 Author Share Posted October 11, 2014 That nailed it perfectly!!! Gerry/Joe/Kirk - Thanks for your help! I don't care what Scott says about you Link to comment Share on other sites More sharing options...
