capitaldesigns Posted December 9, 2019 Share Posted December 9, 2019 I am working on a room addition project with a raised foundation. Chief has a speckled hatch pattern on all of the stem walls, new and existing. I usually show this hatch pattern on new footing only. Is there a way to have the hatch pattern on new the footing and the existing footing not having a hatch pattern. The building departments require us to hatch the new footings to distinguish them from the existing footings. Thanks, Mike Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 9, 2019 Author Share Posted December 9, 2019 I'm on X11 Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 9, 2019 Author Share Posted December 9, 2019 How did you do that ? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 9, 2019 Share Posted December 9, 2019 Here is a present for you Mike: 8 Concret Stem Wall No Fill.calibzFetching info... Link to comment Share on other sites More sharing options...
joey_martin Posted December 9, 2019 Share Posted December 9, 2019 You need to have 2 wall types. One for new and one for existing. Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 On 12/9/2019 at 11:31 AM, joey_martin said: You need to have 2 wall types. One for new and one for existing. Expand This won't change the plan display of footings though, correct? The wall footings are on the same layer (1 layer only) regardless of the wall types and layers. I'm working on the exact same thing right now. There are a couple of choices to distinguish the existing footings from new footings: -draw a new CAD p-line over either the existing or new footings with separate settings -turn off footings on the as-built foundation walls, and replace with slabs or p-solids or a molding, which can be layer set and controlled If the auto-built footings can be layer controlled, I also need to learn how! And right away...I'm completing my drawings as we discuss this. Link to comment Share on other sites More sharing options...
tommy1 Posted December 9, 2019 Share Posted December 9, 2019 Why not just use the wall hatch tool to show new and existing? Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 The OP is about plan display control of footings. This requires a simple workaround as footings won't display differently. I use a standard polyline drawn on top of the footings in plan view for existing walls. I place this polyline on its own layer, copied from the footing layer, and change only the layer line color to a medium gray. Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 9, 2019 Author Share Posted December 9, 2019 Thank you. I see that we can create another footing type. One with the stem wall hatched (new) and the other without a hatch pattern (existing) It would be better if we could put a hatch pattern on the footing as well. Adding or subtracting a hatch pattern on the stem walls works for raised foundations, what about slab footings ? If the project you are working on has a lot of footings it could be time consuming to draw a polyline around them so you can add a hatch pattern. Hopefully CA will give us the ability to add a hatch to the footings. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 10, 2019 Share Posted December 10, 2019 It would be very helpful if Chief would give all of us remodelers more tools for new and existing even though it can all be made a part of a template plan. basically I have set up mine many years ago and not had to mess around with it since except for minor adjustments. Link to comment Share on other sites More sharing options...
