para-CAD Posted September 28, 2019 Share Posted September 28, 2019 Where is the check box to permanently disable the automatic label that appears just below the bottom of the exported item on the layout page? It defaults to Elevation [space] and then a number. I never use this and so every time I export to layout I have to "o,o", Open Object, and Suppress Label. I haven't found where I can set that in Preferences or Default Settings to never come on. Thanks in advance for help with this. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 28, 2019 Share Posted September 28, 2019 Do you use Layout Box Labels for other views ? Link to comment Share on other sites More sharing options...
tommy1 Posted September 28, 2019 Share Posted September 28, 2019 9 hours ago, para-CAD said: I haven't found where I can set that in Preferences or Default Settings to never come on. I don't have this issue. I do however have the layout box labels turned off in my layout template. I assume that's why I don't have this problem. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 28, 2019 Share Posted September 28, 2019 I made this suggestion a while back https://chieftalk.chiefarchitect.com/topic/22289-defaults-for-layout-box-l CA has not responded. Link to comment Share on other sites More sharing options...
tommy1 Posted September 28, 2019 Share Posted September 28, 2019 As mentioned from me earlier, I never have the layout box label show in my layout when sending anything to the layout. I guess for the reason mentioned. Link to comment Share on other sites More sharing options...
joey_martin Posted September 28, 2019 Share Posted September 28, 2019 Turn off the label in the layout layer set. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 28, 2019 Share Posted September 28, 2019 I would - if there were Defaults for Layout Box Labels - specify the label to use the %box_scale% macro as that Label and offset it in the "y" direction so it would be inside the Layout Box. That would provide a scale that would be correct regardless of what scale the view was sent to Layout. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 28, 2019 Share Posted September 28, 2019 13 hours ago, para-CAD said: I never use this and so every time I export to layout I have to "o,o", Open Object, and Suppress Label. The other use for layout labels is just to keep you a little more organized which solves the initial problem quite easily by just dragging the label just beyond the border of your layout so it will not print but is still visible when working. There are a variety of macros that can be added to keep you informed of the source for each layout box etc. Or leave it were it is and turn off before printing. Link to comment Share on other sites More sharing options...
Dermot Posted September 28, 2019 Share Posted September 28, 2019 Currently, there are no defaults for layout box labels. If you don't want to use them, then just turn off the layer as suggested by Tommy. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 28, 2019 Share Posted September 28, 2019 23 minutes ago, Dermot said: Currently, there are no defaults for layout box labels. Yes, that's true. It's something I requested back in April and it would sure be nice to have them. Link to comment Share on other sites More sharing options...
para-CAD Posted September 28, 2019 Author Share Posted September 28, 2019 Thanks. I never imagined that the layout layer defaults would be driving the label on the incoming item from a plan. It's defaulted ON and I had reached the point where I was tired of wasting 4 extra mouse actions to remove it every time I sent something to layout. This is now OFF in my template file. Y-E-E-E-S-S-S-S!! 1 Link to comment Share on other sites More sharing options...
