Dwg Import Issue
lbuttery
The attached DWG file is imported as a single line ?
it is suppose to be a floor plan of a suite of rooms I am renting for my Foundation's museum
I used the import wizard and accepted the default settings
is this a "bad" file or am I doing something wrong
the file is only 114 KB so I suspect it is a "bad" file ?
my experience with importing DWG's is minimal
I used to have a viewer on my prior PC
but don't remember the name
what is a decent free viewer to use ?
Lew
NACC SUITE 118. Level 0.zipFetching info...
Todd:
thanks for the reference
I now have Draftsight
once I saw that the file was good
I played with Chief's import settings until it came into Chief properly
I was not able to get the CAD to Walls tool to work
so I had my partner/friend trace over it
I find the CTW tool to be worthless
Lew
since I already have Draftsight installed
should I swtich to Solidworks Edrawings ?
I only plan to use it to verify that a CAD file "works"
before importing into Chief
I probably won't be doing that too often either
Lew
No Lew. Draftsight is enough for you. On a dwg such as this that was so screwed up, and without you having any knowledge with autocad type stuff, it would be more a waste of your time trying to deal with it rather than letting someone here help you. That is unless you want to learn a new program?  :huh:
