lbuttery Posted October 2, 2014 Share Posted October 2, 2014 The attached DWG file is imported as a single line ? it is suppose to be a floor plan of a suite of rooms I am renting for my Foundation's museum I used the import wizard and accepted the default settings is this a "bad" file or am I doing something wrong the file is only 114 KB so I suspect it is a "bad" file ? my experience with importing DWG's is minimal I used to have a viewer on my prior PC but don't remember the name what is a decent free viewer to use ? Lew NACC SUITE 118. Level 0.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 2, 2014 Share Posted October 2, 2014 I got similar results as you Lew. I have a feeling the file was exported incorrectly. And word on the street is that the best free AutoCAD-like software is DraftSight. Link to comment Share on other sites More sharing options...
lbuttery Posted October 2, 2014 Author Share Posted October 2, 2014 Michael: thanks for confirming I contacted the building manager about trying again I'll check out Draftsight Lew Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 2, 2014 Share Posted October 2, 2014 same thing here also , single line Link to comment Share on other sites More sharing options...
lbuttery Posted October 3, 2014 Author Share Posted October 3, 2014 Perry: thanks for looking Lew Link to comment Share on other sites More sharing options...
lbuttery Posted October 3, 2014 Author Share Posted October 3, 2014 Hmmm, the file opens ok in Draftsight ??? Lew Link to comment Share on other sites More sharing options...
lbuttery Posted October 3, 2014 Author Share Posted October 3, 2014 I tried saving it from Draftsight but no joy same single line ??? Lew Link to comment Share on other sites More sharing options...
lbuttery Posted October 3, 2014 Author Share Posted October 3, 2014 JOY JOY JOY made a few other setting changes I'll go back and isolate which one is the key Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted October 3, 2014 Share Posted October 3, 2014 it was importing as 2 lines until I checked the box for "import hatch entites" then it came in ok. Link to comment Share on other sites More sharing options...
lbuttery Posted October 3, 2014 Author Share Posted October 3, 2014 yep, it was "import hatched entities" that worked Lew Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 3, 2014 Share Posted October 3, 2014 Usually Chief recommends you turn off import hatching, so my is off. Whoever sent you that must have had some layers different than usual. Link to comment Share on other sites More sharing options...
lbuttery Posted October 3, 2014 Author Share Posted October 3, 2014 Perry: thanks seems there are a zillion ways to do things .... Lew Link to comment Share on other sites More sharing options...
4hotshoez Posted October 7, 2014 Share Posted October 7, 2014 "SolidWorks eDrawings" is a free viewer that works on both Mac and Windows and the file does have something on it. See the attachment. Link to comment Share on other sites More sharing options...
lbuttery Posted October 7, 2014 Author Share Posted October 7, 2014 Todd: thanks for the reference I now have Draftsight once I saw that the file was good I played with Chief's import settings until it came into Chief properly I was not able to get the CAD to Walls tool to work so I had my partner/friend trace over it I find the CTW tool to be worthless Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted October 7, 2014 Share Posted October 7, 2014 SolidWorks is part of the Draftsight "Group" at least Draftsight's followup emails have included SolidWorks materials Link to comment Share on other sites More sharing options...
lbuttery Posted October 7, 2014 Author Share Posted October 7, 2014 since I already have Draftsight installed should I swtich to Solidworks Edrawings ? I only plan to use it to verify that a CAD file "works" before importing into Chief I probably won't be doing that too often either Lew Link to comment Share on other sites More sharing options...
ACADuser Posted October 7, 2014 Share Posted October 7, 2014 Wow what a mess. That DWG is nothing but hatches, no lines or plines. Link to comment Share on other sites More sharing options...
ACADuser Posted October 7, 2014 Share Posted October 7, 2014 See attached file with hatches deleted & only hatch outlines remain. NACC SUITE 118. Level 0.zip Link to comment Share on other sites More sharing options...
Gary_M Posted October 7, 2014 Share Posted October 7, 2014 No Lew. Draftsight is enough for you. On a dwg such as this that was so screwed up, and without you having any knowledge with autocad type stuff, it would be more a waste of your time trying to deal with it rather than letting someone here help you. That is unless you want to learn a new program? Link to comment Share on other sites More sharing options...
lbuttery Posted October 7, 2014 Author Share Posted October 7, 2014 Noooooo, nothing new seriously, I just wanted to be able to see if the CAD file had something in it Lew Link to comment Share on other sites More sharing options...
