para-CAD Posted September 3, 2019 Share Posted September 3, 2019 So this is the second time a client builder of mine has taken an Arch D scaled PDF plan and printed it to 11x17 [ANSI B] on an HP Officejet 7612 and also an HP Officejet 8600 Premium from an Apple computer and the pages with exported 3D images all print with a solid black background. (Those are all the variables I can think of). When I send the same PDF file to my Brother MFC laser printer it prints 8.5x11 fine.....no black issues. Since I can't reproduce the condition I can't troubleshoot it. Has anyone else experienced and more importantly - SOLVED this? Thanks in advance for any and all help! - Mike 1 Link to comment Share on other sites More sharing options...
LevisL Posted September 3, 2019 Share Posted September 3, 2019 Hi Mike, I bet they printed from the Preview app on the Mac computer. I've seen a lot of this. It's just been since the Mojave OS was released. I had to switch to print from Acrobat Reader instead of Preview for that exact reason. 2 Link to comment Share on other sites More sharing options...
LevisL Posted September 3, 2019 Share Posted September 3, 2019 Here's one of mine from a little while back! I think the bug is when the images have a transparent background from what I can tell. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 3, 2019 Share Posted September 3, 2019 On 9/3/2019 at 9:32 PM, LevisL said: I think the bug is when the images have a transparent background from what I can tell. Expand Yes that is correct. It seems to be an issue with .png files. Adobe seems to be able to handle it while others can not. Not sure it is exclusively a Mac problem as it seems to happen with Microsoft as well. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 4, 2019 Share Posted September 4, 2019 This is a “problem” with a handful of apps, but it can usually be solved by simply changing the background color being used for that particular program from black to white. I believe this is the case with Apple’s Preview app as well. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted September 4, 2019 Author Share Posted September 4, 2019 Thanks everyone. Yes...builder was printing from Apple's native Preview app. When he tried Acrobat Reader, it printed fine, no issues. Crisis averted. Link to comment Share on other sites More sharing options...
LevisL Posted September 4, 2019 Share Posted September 4, 2019 On 9/4/2019 at 12:19 AM, Alaskan_Son said: I believe this is the case with Apple’s Preview app as well. Expand I'm gonna have to disagree with you on that one! I never changed my background color from the default. I also don't use the Dark Mode introduced with the release of Mojave. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 4, 2019 Share Posted September 4, 2019 On 9/4/2019 at 4:45 AM, LevisL said: I'm gonna have to disagree with you on that one! I never changed my background color from the default. I also don't use the Dark Mode introduced with the release of Mojave. Expand I could very well be wrong about that. I just saw that it should be possible doing a quick search. I do know for a fact that it is the case with a handful of other programs though. Very commonly, the default background color is black. I've had to change this setting on some of the software I use in order to actually see and work with black images that have transparent backgrounds. Link to comment Share on other sites More sharing options...
Chrisb222 Posted September 4, 2019 Share Posted September 4, 2019 Happening here too. One solution I found was printing directly from Chief. Not a solution for everyone, I know, but just throwing it out there. 1 Link to comment Share on other sites More sharing options...
DrewFenton Posted September 4, 2019 Share Posted September 4, 2019 It is happening to me in X10 using the integrated Adobe Acrobat DC print driver, or direct to Adobe. It is only my legends, which are grouped under a single layer before sending to layout. They appear fine in layout but you can quickly see in the print preview that the backgrounds on all of them are black. And oddly the rectangles in the plan are shown as rounded corner boxes in PDF, filled with black. Pg 2 and 3 of attached PDF show the results. Even odder, I brought up an old plan and created a new layout and it does not happen. I can't figure it out! 58 Bees Creek.pdf Link to comment Share on other sites More sharing options...
LevisL Posted September 4, 2019 Share Posted September 4, 2019 On 9/4/2019 at 6:16 PM, DrewFenton said: It is happening to me in X10 using the integrated Adobe Acrobat DC print driver, or direct to Adobe. It is only my legends, which are grouped under a single layer before sending to layout. They appear fine in layout but you can quickly see in the print preview that the backgrounds on all of them are black. And oddly the rectangles in the plan are shown as rounded corner boxes in PDF, filled with black. Pg 2 and 3 of attached PDF show the results. Even odder, I brought up an old plan and created a new layout and it does not happen. I can't figure it out! 58 Bees Creek.pdfFetching info... Expand That almost looks to me like you have a really heavy lineweight for your legend borders. 1 Link to comment Share on other sites More sharing options...
DrewFenton Posted September 4, 2019 Share Posted September 4, 2019 You are a genius Levin! That is exactly what it was. It was set to 5000. I believe I was trying to thicken them some in the plan views but no matter what I typed in, it had no affect on plan. But I guess it does have a BIG effect once in Layout. Thank you again, you saved me! Link to comment Share on other sites More sharing options...
LevisL Posted September 4, 2019 Share Posted September 4, 2019 On 9/4/2019 at 9:50 PM, DrewFenton said: You are a genius Levin! That is exactly what it was. It was set to 5000. I believe I was trying to thicken them some in the plan views but no matter what I typed in, it had no affect on plan. But I guess it does have a BIG effect once in Layout. Thank you again, you saved me! Expand No problem! Actually, you can see the effect in plan view. Just toggle the 'Line Weights' icon on. I usually leave mine 'on' unless I need to do more intricate detailing and the line weights get in the way of being accurate. Also, when I send a view to layout, I always check 'Use Layout Line Scaling' below the scale. This way the line weights and dash lengths look consistent from one view to the other, regardless of scale And lastly, it helps if your drawing sheet setup in both plan and layout both have the same line weight settings. I use 1 = 1/100mm, which I think is the default. I know @dshall and I had a gotomeeting last year where we played around with the line weight settings in plan that were different than in layout and we had some odd results. Link to comment Share on other sites More sharing options...
DrewFenton Posted September 4, 2019 Share Posted September 4, 2019 These are really good suggestions. I am going to experiment. I appreciate you taking the time to help. Link to comment Share on other sites More sharing options...
koukouroukou Posted January 12, 2022 Share Posted January 12, 2022 Searching on internet find this post today because i have the same problem but also i found the solution. my printer is a Samsung M2026. Until yesterday i print my PDF fine. after a pop up window of my printer says this toner has print more pages from that is compatible start to print my invoices that have a PNG picture on it with black background or blur. After many checks i notice one more problem. my cartridge meshed up whit more toner than normally. one more think is the red light that is for ink is on (not blinking). the toner i use is aftermarket and i think and these toners they have some lock like originals. so i change the cartridge with a new aftermarket and the problem solved!!! Magic? I don't think so. sorry for my English and i hope this post helps someone. 1 Link to comment Share on other sites More sharing options...
