wolftide45 Posted August 27, 2019 Share Posted August 27, 2019 I would like to show a window schedule on first floor and begin numbering for windows, say numbers 1-10. Then, I would like to show a second floor schedule that picks up the numbering where the first floor numbering left off, 11-16 or whatever. Is this possible to do with the schedule feature? Link to comment Share on other sites More sharing options...
MarkMc Posted August 27, 2019 Share Posted August 27, 2019 Yes. Don't check 'group similar ". Will be easiest if first floor windows are placed first, program numbers by the order placed BUT you can always drag up and down in the Schedule to renumber or use the icon to do it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 28, 2019 Share Posted August 28, 2019 There are attributes: floor_number simple_schedule_number that you can use in macros in your schedules and in labels. This works for Doors, Windows, Cabinets, Appliances, Fixtures and even to a certain extent for Rooms. Link to comment Share on other sites More sharing options...
wolftide45 Posted August 28, 2019 Author Share Posted August 28, 2019 Eric - yes that was the idea, place a schedule that can be referenced on F1 floor plan for F1 windows and another on F2 floor plan for F2 windows. I did not want to start the numbering over at "1" when I changed floors. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 28, 2019 Share Posted August 28, 2019 The only way to do that is to use a custom macro. Link to comment Share on other sites More sharing options...
wolftide45 Posted August 28, 2019 Author Share Posted August 28, 2019 Thx Joe, I'm pretty green on macros. Could you point me in the right direction on doing this? I'm assuming a custom macro in the window labels and then would the "Number" column report the macros accordingly? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 28, 2019 Share Posted August 28, 2019 I can write the macros for you (for a fee) but I'm pretty sure you would need to upgrade to X11 for it to work. X10 might work but X9 doesn't have the required attributes. The windows would need to have a custom field which would then be used as a column in the window schedule. Link to comment Share on other sites More sharing options...
wolftide45 Posted August 28, 2019 Author Share Posted August 28, 2019 Thx Joe, I will probably have to wait - thx for the help anyway Link to comment Share on other sites More sharing options...
MarkMc Posted August 28, 2019 Share Posted August 28, 2019 I keep all schedules in a CAD detail. Use one schedule, be sure to include a column for floor and keep an eye on number order. Send to layout page for Floor 1, crop so it doesn't show floor 2. Copy, go to second floor page, paste and hold position, then adjust to show only header, copy and paste in place, adjust second copy to show second floor align to header. Joe a few months back we tried on here (and I contacted support) to use a macro that added to the schedule number -does not work. The macro executes before the schedule number. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 28, 2019 Share Posted August 28, 2019 3 hours ago, MarkMc said: I keep all schedules in a CAD detail. Use one schedule, be sure to include a column for floor and keep an eye on number order. Send to layout page for Floor 1, crop so it doesn't show floor 2. Copy, go to second floor page, paste and hold position, then adjust to show only header, copy and paste in place, adjust second copy to show second floor align to header. Joe a few months back we tried on here (and I contacted support) to use a macro that added to the schedule number -does not work. The macro executes before the schedule number. It has to be done by using a single schedule and a custom field. I know it can be done because I've done something similar using the floor-number and simple_schedule_number attributes. Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 28, 2019 Share Posted August 28, 2019 23 hours ago, wolftide45 said: I would like to show a window schedule on first floor and begin numbering for windows, say numbers 1-10. Then, I would like to show a second floor schedule that picks up the numbering where the first floor numbering left off, 11-16 or whatever. Is this possible to do with the schedule feature? Easy, I do this on every plan. Once you have your second floor window schedule in place and set to display only the second floor windows, select one of the windows and hit the "down" button in the lower toolbar to move it down in numbering sequence. Keep hitting down (or UP) with each window to organize their number and place in the schedule as desired. See pic. Link to comment Share on other sites More sharing options...
MarkMc Posted August 28, 2019 Share Posted August 28, 2019 2 hours ago, Joe_Carrick said: I know it can be done So where were you when we were trying to solve this for someone on here. Michael had not luck and tech told me it couldn't. Tell me what needs to be done to get the output to read properly in the schedule. The macro evaluates correctly, just not in the schedule. I could see using this in a different situation if it would work or I wouldn't have bothered calling tech. Sched number macro.plan Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 28, 2019 Share Posted August 28, 2019 Guys, you can easily renumber the windows in a schedule using the method I described above. OOB, no macros. Window Schedule.plan Link to comment Share on other sites More sharing options...
MarkMc Posted August 28, 2019 Share Posted August 28, 2019 3 minutes ago, Chrisb222 said: Guys, you can easily renumber the windows in a schedule using the method I described above. OOB, no macros. Window Schedule.plan Nice trick BUT you left out that you have to start with a schedule that first shows objects from all floors, then change it to show just the floor you are on. If you start with a second schedule that only shows objects on a single floor the numbers start over and your trick doesn't work. Link to comment Share on other sites More sharing options...
MarkMc Posted August 28, 2019 Share Posted August 28, 2019 Tried this on a set of cabinet schedules by room. Thought this might make multiple schedules faster but alas not so good. Plan with say 50 objects placed at varied times so not in order. Reorder them with the buttons takes forever so reorder them by dragging. Copy schedule, change first schedule to specific room. Paste schedule and change to a different room. Numbers revert to original order and as noted moving by the icon for 50 items is a non starter for me. Too bad. Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 28, 2019 Share Posted August 28, 2019 25 minutes ago, MarkMc said: Nice trick BUT you left out that you have to start with a schedule that first shows objects from all floors, then change it to show just the floor you are on. Nope, I just did it again, started with a new OOB Residential template, and after changing Window Schedule defaults to NOT include objects from all floors, created a new schedule for each floor, and changed the two second floor windows from W01 and W02 to W03 and W04. 31 minutes ago, MarkMc said: If you start with a second schedule that only shows objects on a single floor the numbers start over and your trick doesn't work. It's not a trick and it DOES work for what the OP wants, without macros. That's the point of my post. I've done this many times using copy/pasted schedules, new schedules, schedules from old plans... it works. 1 Link to comment Share on other sites More sharing options...
DG1949 Posted August 29, 2019 Share Posted August 29, 2019 Thanks, Chris. Very good to know! Link to comment Share on other sites More sharing options...
robdyck Posted August 30, 2019 Share Posted August 30, 2019 On 8/27/2019 at 3:02 PM, wolftide45 said: I would like to show a window schedule on first floor and begin numbering for windows, say numbers 1-10. Then, I would like to show a second floor schedule that picks up the numbering where the first floor numbering left off, 11-16 or whatever. Is this possible to do with the schedule feature? The simplest way to do close to what you want is to use a prefix that references the floor number. No macros, still very logical, and it matches the method of communication that you're aiming for. Include a legend that shows how the labeling works. It will also simplify your schedule numbering if you need to make a change after completion. It'd be a PITA to try to get , let's say, a new window #23 from the first floor to the second. Referencing each floor only can be logical and practical. 1 Link to comment Share on other sites More sharing options...
