Heavy timber deck construction
dshall
Hi Guys,  I need to do a Heavy timber deck construction.
I think that means:
8x8 posts (or is it 6x6,  I have seen it both ways)
6x8 or 4x10 beam minimum
3x ledgers
2x6 t&g decking for a roof
.......and.......  what can I use for DECKING for a deck?  I want to use 2x6 decking with a 1/8" gap but I do not think it will work
Trex is is out because it is flammable...  any ideas for the decking?
On 6/14/2019 at 2:32 PM, SNestor said:
It looks like TimberTech Azek has a class "A" flame spread index.  https://www.timbertech.com/imagine/stories/timbertech-azek-receives-class-a-flame-spread-index-rating
Decks are difficult in California...well, so is everything else - so it figures.  Better than burning your house to the ground...:huh:
Thanks Steve....  that might work...
20 hours ago, DRAWZILLA said:
how about good ole Dex-o-tex over conc. base?
Nope,  he wanted the decking.  I started with the dex-o-tex.
BTW,  This is in the middle of La Jolla but just so happens to have a bit of natural canyon behind it so it needs to be 1-hour.  The house two doors down recently had a huge deck put on and they used Trex decking.  Why can they use Trex and I can't?  I do not know.
I am really getting burned out with the land mines I am always seeming to step in.
Recently went to submit a project,  a new unit on a lot with an existing house (zoned for the extra unit),  and the submittal was rejected because I did not have a landscape and irrigation plan.  I have never had that happen unless it was for a CDP.....  which I thought would be needed.....  but nope,  for some unknown reason,  the owner says we will not need one,  he even checked with the city.
Oh well,  if it was too easy,  the owners would do this themselves and I would not have a job .
1 minute ago, Renerabbitt said:
maybe give these guys a call, check for your local distributor..They are getting away with UL listed assemblies on treated lumber:
http://www.frtw.com/?q=distributors
Here is another option.
This is what Fiberon states about their ProTech Advantage Decking
Fiberon Decking
And if you live in a wildfire-prone region, consider ProTect Advantage FR Decking. You'll enjoy all the beauty and benefits of original ProTect Advantage plus the comfort of knowing the "FR" boards have been tested and approved for use in Wildland Urban Interface (WUI) zones.
Fiberon Decking
nice, saved it, +1
I have run into the landscape thing, it's usually a homeowners assoc. requirement, but they want it anyway.   I tell the h.o. to get a landscape architect, I'm not doing it.
tsk tsk no name calling, be nice to your client ;)
Scott,  check the Cal Fire website, State Fire Marshall's Building Materials Listing Program to see
if a product is approved by them.
Here
State Fire Marshall Building Materials Listing Program
I am using IPE and have the approval from SFM
2053-0100.PDF
Here
2053-0100.PDF
THANK YOU J Johnson...   that is the ticket!
