Design to Layout
JbeckWY
I'm taking my first set of plans and sending them to layout. I'm a bit overwhelmed. Does anyone have an outline or something they follow when they create construction drawings? Or good references I can follow? I also may be interested in having someone create them for me (if I can't get through it), is this something that is available?
Thanks,
Jordann
You could download some of the plans from the Samples Gallery , eg the Lake Point Plan and use it for guidance, there is a good set of Videos that go along with that Plan Set too.
There are a number of People on the Forum  who offer paid help to other members too , most have posts in the Offering or Seeking Forum.
Mick.
There are sample plans you can download and use as reference on the website.  It will also depend a lot on the nature of the project and the requirements of the jurisdiction you are building in what a finished set of drawings will look like.
You can post in the Seeking Services forum for someone who is familiar with your local requirements if it is something you can't handle yourself.
The nice thing about Chief Architect is you can quickly produce a basic set of permit drawings or fully illustrated construction document drawings with the same software.
I would also try to find someone in your area who had construction drawings done that was approved for a permit. That will give you a big heads up on what's required in your area. What's required can vary greatly from place to place.
since I worked in the DC metro area that covered DC, MD, VA and over a dozen counties within
I always went to the local permit office website and called them to determine what they needed in the way a permit set
basically never submit more than they need
the more you submit - the more they have to review - the more chances for "rejection"
I'm proud to say that we had a 100% acceptance rate :)
anno-sets were introduced with X4
everything that anno-sets can do we did without them prior to that
but they are a convenience - a great convenience
use the anno-sets provided by CA
then as you get comfortable create others as needed
some users are masters of anno-sets and have 36+ sets
others have less than 10
X10 introduced plansets and again we did everything without them prior
but they are another great convenience
so try to learn how to use them soonest also
start simple and learn as needed
Lew
    31389
    LeighSupplies
    LeighSupplies
  • Similar Content
    • By Arch_Tech
      Hello all,
      I am using CA X13.
      I am designing a house that has a wing that is at 45 degrees relative to the other wing of the house.  I am working with a Home builder and he has shown me that when a house is at 45 degrees, typically the elevation views reflect that by only showing the outline of the structure that is set at 45 degrees, like this.
      As you can see the garage portion is at 45 degrees relative to the elevation view.  I am pretty sure this set was produced with AutoCAD.
      How can I make this happen in CA?
      Thanks in advance!
    • By Renerabbitt
      I offer some of the fastest turnaround in the industry on LARGE complex projects. Need a model built? A rendering complete? Elevations? A fully hosted 3d model to walk through?
      Let me be your first stop to solving your urgent needs.
      Created in Chief Architect X-13 in less than a day
      Other Offer Services Posts:
    • By BreMarieDesigns
      Freelance Architectural Drafter: Ongoing position with a growing design company in East Texas. Assist the Principal Designer with the completion of residential construction documents and modeling. Builder spec homes to large scale high end custom homes. Work remotely within the United States.
      Email resume & portfolio to: breanna@bremariedesigns.com
    • By Paradisaic
      Hello,
      I've been having ongoing issues with coloured elevations once it has been sent to layout. I always get these white dashes throughout the elevation image and I have no idea how to fix this problem. I've attached an image.
      This is my settings when I send to layout:
      Send Options: Entire Plan/View
      Camera View Options: Plot Lines, (Colour Fill, Edge Line Defaults, Pattern Line Defaults all checked)
      Scaling: 1/2" = 1'-0"
    • By IAGArchitectsLtd
      We are based in Trinidad and Tobago but we do drawings for Caribbean, USA etc. We have more than 10 years experience in  Chief Architect , specialising in Architectural, Structural, Plumbing, Electrical Drawings,3D Renderings, Kitchen cabinetry drawings, Interior Designing etc. You can also view our Facebook Page and Customers reviews,https://www.facebook.com/IAGArchitectsLtd1/ . The exterior designs attached are our work, all rights reserved. Email Address : iagarchitectsltd@gmail.com and contact number : 1-868-266-2444,1-868-487-1973,Thank you kindly.
