Labels showing through walls
gdesignbuild
I am trying to finish up a set of plans and when I turned on window and door labels on the elevations, it shows the labels for all windows and doors, even through walls, etc. I cannot figure out how to get it back to normal to show just the ones within the view. I can't find a setting to change this. Can anyone help?
I have seen this reported before but don't remember the fix offhand , so I'd suggest doing a Forum Search for the Labels issue.
It is usually suggested to attach a copy of the File or a Test plan showing the issue if at all possible too.
Probably a good idea to do you Forum signature , especially with the Version , as that info maybe important for the "fix"
Update video card driver.  If that doesn't fix it, possibly roll back video card driver.  Could also just be an insufficient video card, not sure.  At any rate, you should be able to fix no matter what  by opening those offending windows and doors, clicking on the label tab, and selecting "Hide In This View".  This can be made easier and quicker by temporarily dragging/relocating the camera so that you can actually see and select the offending objects or by simply using the Delete Surface tool.
Those labels may be from the windows and doors on the other side of the building.  If they are designated as 'show label in this view', not automatic, they will show.
The easiest way to see if this is the case is to move your camera into the building so you can see the windows and doors.  Open the unit's label tab and change the display to 'automatic'.  Move your camera back to the original location and your labels should be gone.
  • Upvote 2
Expand
Thankfully someone's memory is better than Mine :)   , thanks Maureen
First, try Perry's suggestion of changing your Hardware Edge Smoothing to High.  There is a bug with some video card drivers that can cause this problem.  Turning the edge smoothing to high should also make your views look better and probably won't affect performance in a noticeable way.
If that doesn't work, I would try Michael's suggestion of updating your video card drivers.
If neither of those solutions works for you, you can always manually turn off or on individual labels in a specific camera view (using Michael's, Steven's, or Maureen's suggestions).
If all else fails, then I would contact technical support during our normal business hours.
