MN_JohnH Posted December 14, 2018 Share Posted December 14, 2018 Wondering if there is a way to make letters into polyline solids so that I can attach them to another solid to make an embossed look? Link to comment Share on other sites More sharing options...
rlackore Posted December 14, 2018 Share Posted December 14, 2018 Can't do it in Chief. I suggest Sketchup, which will create any font installed on your system as 3D text: With a little work you can do embossing, then import it into Chief: 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 14, 2018 Share Posted December 14, 2018 If I need 3D letters like that, Here what I do: Use Sketchup to create the letters Import those into Chief as a symbol Create a CAD Detail From View to get the extrusion shapes Cut/paste those into plan Convert them into polyline solids Convert to solids if necessary 1 Link to comment Share on other sites More sharing options...
MN_JohnH Posted December 14, 2018 Author Share Posted December 14, 2018 Thanks guys. Very good. Looks like eventually I am going to have to quit avoiding learning a bit about sketchup. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 14, 2018 Share Posted December 14, 2018 For whatever its worth, this one thing (3D lettering) is almost the only thing I personally use Sketchup for anymore. 1 Link to comment Share on other sites More sharing options...
MN_JohnH Posted December 14, 2018 Author Share Posted December 14, 2018 From what I can see, the free sketchup will not do lettering and I don't think I am in the mood to pay for it so I will have to find a way to work around this. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 14, 2018 Share Posted December 14, 2018 11 minutes ago, MN_JohnH said: From what I can see, the free sketchup will not do lettering and I don't think I am in the mood to pay for it so I will have to find a way to work around this. Thanks! It's in there. Go to Tools>3D Text 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 14, 2018 Share Posted December 14, 2018 Here is a link to a thread where @yusuf-333 demonstrates a method of sending to PDF and converting to DWG that works for text and dimensions. Not all Chief but it very easily could be in the next version or two. 1 Link to comment Share on other sites More sharing options...
BrownTiger Posted December 14, 2018 Share Posted December 14, 2018 https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/639 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 14, 2018 Share Posted December 14, 2018 Here's a quick sloppy example of what I typically do... https://youtu.be/e9BVQ4cQcTc 2 1 Link to comment Share on other sites More sharing options...
williambentley2 Posted July 16, 2022 Share Posted July 16, 2022 They should frankly fix this sooner rather than later. It is a serious flaw in the CAD aspect of this program. What it does not allow for is the ability to apply lettering onto 3D scenes seamlessly. I end up using CorelDRAW, but I could just as easily use sketchup or Illustrator. It's just a kuldgy way to handle text when you need it to be applied as polylines. Link to comment Share on other sites More sharing options...
ericepv Posted July 16, 2022 Share Posted July 16, 2022 There are a few 3D fonts available in the Bonus Catalogs. Link to comment Share on other sites More sharing options...
