PBR - how do I get rid of big white spot on the ceiling?
Cheryl_C_Crane
I think Perry is right and even though it looks like you've already 'added lights' you need to go to 3D>lighting> 'add lights' and add one from there. You can lower the lumens and get it out of the way but I could not find a way to turn off that light by any other means. Are there other options to turn off that light?
That ceiling blob of light seems wide and oblong and pretty intense.  The point light generated by CA when there are no lights is usually more subdued and you do have lights defined.  Are sure sure it's not a reflection off the island counter?  Try closing all lights but the sconce to validate?
There are additional lights but unless a light was added using the 3D>Lighting>Add Lights Chief's default light will remain. It could also be very bright for various reasons as other settings might have been changed. Adding a light using the 3D>Add lights command is a very simple test.
Without a plan difficult to guess at all the options though.
EDITED above
1 hour ago, HumbleChief said:
There are additional lights but unless a light was added using the 3D>Lighting>Add Lights Chief's default light will remain ...
From my testing:
  • Create a 4 wall room + Define a camera in there + switch to full camera 3D view = CA default light appears.
  • Drag a recessed light to that 2D plan + switch to full camera 3D view = no CA default light, just the recessed.
I added the lights using the various Lighting Libraries not from the 3D>Lighting>Add Lights.
Never before have I seen a default interior blob light remain after this many additional room lights were placed.
Thought that it was just a setting, but here is the file. Thanks to ALL, I sincerely appreciate your time, ~Cheryl
Jackson Jason Kit (2).zipx
3 hours ago, cv2702 said:
From my testing:
Right you are and wrong I are about the lighting...wonder what's going on in the plan - oh yeah the plan....
Your invisible wall defines a room that has no lights in so Chief is placing a light source (may be because the camera is in that room?) either add alight or delete the invisible wall and use a floor material region instead.
Thanks, Mark. Again it was User Error and not Chief. I was only given 2 dim strings and asked to design a kitchen. I have no idea what is going on beyond the L shape so I drew an Invisible Wall. I've learned from this experience! Thanks again, ~Cheryl
