On 4/23/2018 at 4:05 AM, DavidJPotter said:
A recent project in progress
RT or PBR?
5bc8e59f41688_KitchenMD1.thumb.jpg.120fc30e3390613eb11b03e8beba981e.jpgBasement apartment kitchen design.  PBR.  No first floor or roof, so I guess that is why the ceiling rendered brilliant white.
Takes some getting used to - but not bad for instant gratification..!
5bd9d341b2dbc_Untitled24.thumb.jpg.6e3d6e66279ccf3a665da6f62206df91.jpg5bd9d340e36a2_Untitled22.thumb.jpg.1c79176baf9138eb3c0f9cbd1d9262b4.jpg
That is quite a kitchen layout there...
I have found if you use framing members instead of soffits for your beams and rafters, the wood grain works better.
Ooooooooo - Right you are - Learn something new..! THX
You’re welcome!  My pleasure.  Glad to be able to give back a little for all I have learned from this community.
Settings for the cove lighting in this PBR render
Note: Equidistance is from 8 inches.
         Each Light intensity can be much lower
New project that I'm working on, I find that when it comes to PBR, I can get better more realistic results with night time views and lights, in comparison to day time.
I think they both look good. Maybe the reason you prefer the night time is due to the fact that a lot of the detail is hidden due to the low light levels. On interior shots with higher levels of light it's more obvious when a model or material is not quite right.
Yeah I think you hit the nail on the spot.  Many times high levels of day time light really make furniture and all look just not right.  I tried your tips on max sun lumens and lights at 3000, played around with the settings, sometimes it hit the spot, sometimes it just over blew it....still trial and error
I certainly find that many of the models are too simplistic and as such they just look fake.
Not sure I'm understanding correctly your reference to my tip on maximum sun lumens. I believe I've been trying to emphasizing that there is a balance between the sun intensity and the interior light intensities that one needs to achieve. I typically try to find the right sun intensity first and then adjust my interior light intensities to suit. Maybe you are referring to one of my recommendations as to setting the PBR camera exposure to max and the brightness to 100% and then adjusting the lighting to work at these settings. This recommendation will most likely result in your sun intensity and light intensities being set very very low. The reason I make this suggestion is that at those PBR settings you will not get the effect where the PBR does not try to automatically adjust the apparent intensities as you change your lighting.
    27478
    Oilersfan20
    Oilersfan20
  • Similar Content
    • By robdyck
      A bit late in the day to be starting an old topic. What the heck is the deal with random wall lighting issues in PBR? I've tried every toggle and adjustment I can find but I can't get a couple of walls to display properly. It's clearly not a specific lighting issue because the problem is with a few walls. I recorded the PBR adjusting itself and somewhere along the way it gets it just right...but then just keeps on going. All I'd need is a slider tool so I could manually reverse / forward that process and then stop it where I'd like it.
      And while I was working on this I had an epiphany! I added a wallcovering to my offending walls, using the same material, and BOOM! They all play along now! This could possibly go in the 'tip and tricks' section.
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      CLOUD SYNC MULTIPLE USER LIBRARIES FOR MULTIPLE DEVICES/END USERS       DIRECT LINK TO VIDEO X64 SHELL EXTENSION  X32 SHELL EXTENSION PAYPAL THE GUY THAT WROTE THE EXTENSION  ADVANCED LIBRARY SEARCHES DIRECT LINK TO VIDEO       INTRO TO ADVANCED PBR METHODS DIRECT LINK TO VIDEO CREATING ADVANCED MATERIALS IN PHOTOSHOP   DIRECT LINK TO VIDEO AUTUMN LEAVES MATERIAL FILE CREATE A HOTKEY TOUCHPAD USING YOUR ANDROID OR IPAD TABLET     DIRECT LINK TO VIDEO LINK TO SOFTWARE WEBSITE TOUCHOSC METHOD FOR CREATING CON-DOCS IN .PLAN      USING AN IPAD TO REMOTELY CONTROL CA. METHOD OVERVIEW   ADVANCED TOOLBAR CONFIGURATIONS   NEW!!! 08/28/2019
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By GCCISarah
      Hi all,
      All mirrors from the catalog(s) that I am placing show a bright yellow cast and pixels on the reflective surface of the mirror itself. The mirror IS reflecting the room around it, but the bright yellow color and pixelation never resolves itself. The first photo is the 'Standard' camera view rendering technique, where the yellow is at its brightest. The second attachment is 'Physically Based' rendering technique, where the yellow is faded a bit.
      I had no problems in X10, but this issue has been in all of my plans so far using X11.
      Any thoughts? The mirror material is set as a 'Mirror', with 100% reflection. I've not changed any defaults, preferences, or qualities about the mirror material or camera views that I could think would affect the reflective quality. Help appreciated.
    • By TheKitchenAbode
      Take your PBR to a new level of realism with some simple Photoshop crops. Took about 10 minutes.
      Before
      After
    • By Grumpka
      Nobe messing with lighting settings in PBR. Very tricky to balance sun strength and room lights. I'll get there though.
