dskogg Posted February 9, 2018 Share Posted February 9, 2018 I updated to the newest nvidia driver and now my standard view and pbr view are the same....any thoughts? both have many lights and shadows turned on...normally when you change to pbr it takes a few seconds to adjust...not doing this now. first pic is standard the 2nd pic is pbr. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 9, 2018 Share Posted February 9, 2018 You can turn PBR into standard render by selecting Enhanced Lighting in Preferences but that looks like they are both PBR ?? Maybe post the driver version in case anyone else has updated. Very strange indeed. Link to comment Share on other sites More sharing options...
dskogg Posted February 9, 2018 Author Share Posted February 9, 2018 Link to comment Share on other sites More sharing options...
Chopsaw Posted February 9, 2018 Share Posted February 9, 2018 If you select Global Illumination what happens ? Link to comment Share on other sites More sharing options...
dskogg Posted February 9, 2018 Author Share Posted February 9, 2018 Nothing happens Link to comment Share on other sites More sharing options...
Chopsaw Posted February 9, 2018 Share Posted February 9, 2018 On 2/9/2018 at 1:37 AM, dskogg said: Nothing happens Expand As in Nothing different ? I get PBR with Global Illumination and Standard view in PBR Mode with Enhanced Lighting set. Link to comment Share on other sites More sharing options...
dskogg Posted February 9, 2018 Author Share Posted February 9, 2018 Nothing.. I can change the exposure from .2 to .9 and no change what so ever Link to comment Share on other sites More sharing options...
MarkMc Posted February 9, 2018 Share Posted February 9, 2018 Ran across a discussion of that driver this morning. There were some interesting things said about nVidia drivers in general. Now these are mostly geeks and gamers so some of it is unintelligible to me. http://forum.notebookreview.com/threads/nvidia-geforce-drivers-v-390-77-whql-findings-fixes.813230/ I don't update drivers unless the mfg offers them. On my last machine I updated the nVidia driver because it's so often touted on here. Only time I ever had trouble with it. I'd at least read the release notes to see if it offered anything relevant to me. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 9, 2018 Share Posted February 9, 2018 Brian Beck has said Global Illumination should NEVER be turned off in Preferences , doing that is for T.S. use only. If you have a decent Videocard hardware edge smoothing can be on HIGH and texture compression OFF , TC is not normally needed for modern Videocards. My Enhanced lighting is Greyed out ? I just noticed on check your setting against mine , not sure about that but I am seeing alot of Black in PBR with 390.77 though I don't know if 390.77 is the Reason , I was going to try 382.05 again to compare since Drivers above that seem to have various Issues. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 9, 2018 Share Posted February 9, 2018 Any chance that in the update process the card Chief uses got changed to the on board graphics card? Link to comment Share on other sites More sharing options...
dskogg Posted February 9, 2018 Author Share Posted February 9, 2018 Hi I looked at this and ca is still using nvidia... pita... now I have to figure out what to do to get it back to at least working in pbr Link to comment Share on other sites More sharing options...
dskogg Posted February 9, 2018 Author Share Posted February 9, 2018 Here is the file for anyone that wants to try and see if they have the same problem, it would be interesting to see someone try with the new nvidia driver 390-77 30 Christie estates v1.3 (2).zip Link to comment Share on other sites More sharing options...
BrianBeck Posted February 9, 2018 Share Posted February 9, 2018 PBR will not function in any way if you turn off Global Illumination. Has Mick mentioned this should never be toggled unless you are troubleshooting an issue with technical support. I would also suggest you uncheck texture compression, leaving this checked will cause 3D views to take longer to generate. If you are still having issue after doing this I would suggest contacting our Tech Support team and troubleshooting the issue further with them. Link to comment Share on other sites More sharing options...
dskogg Posted February 9, 2018 Author Share Posted February 9, 2018 Thanks Brian for some reason i had global illumination turned off? But i still get a very dark room next to room where i have a camera, i have sent it in for you guys to review. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 9, 2018 Share Posted February 9, 2018 On 2/9/2018 at 1:15 AM, Chopsaw said: If you select Global Illumination what happens ? Expand On 2/9/2018 at 1:37 AM, dskogg said: Nothing happens Expand ? Link to comment Share on other sites More sharing options...
jonboy Posted February 9, 2018 Share Posted February 9, 2018 I have the same issue .. PBR is the same as a standard view. Preferences ... under render... global illumination off .. improve lighting on or off no difference Link to comment Share on other sites More sharing options...
Kbird1 Posted February 9, 2018 Share Posted February 9, 2018 On 2/9/2018 at 5:42 PM, Chopsaw said: ? Expand I wonder if people read my posts too sometimes so once again.... Brian Beck has said Global Illumination should NEVER be turned off in Preferences , doing that is for T.S. use only. If you have a decent Videocard hardware edge smoothing can be on HIGH and texture compression OFF , TC is not normally needed for modern Videocards. Link to comment Share on other sites More sharing options...
dskogg Posted February 9, 2018 Author Share Posted February 9, 2018 Yes I should read thoroughly, I was mixing up global and enhanced lighting... thanks for all who tried to help me. Link to comment Share on other sites More sharing options...
