ComputerMaster86
Back-Up Program Preferences
Once a person has their program preferences tweaked to the way they want them, what CA system file is those settings stored in?  Ideally, you should be able to back-up those settings in the event that something gets goofed up and those settings need to be re-adjusted.
I figured it out.  I just had to replace the .ini file with my back-up copy and I got my settings back.
Probably a good idea ....what is the location of the .ini file that worked , thx.
KB
I thought defaults and preferences could be saved as templates ???
Lew
Lew
defaults can be imported from an existing plan , AFAIK Preferences cannot be and need to be set each new version ,
not sure if they are preserved with an Upgrade version to version though. ( ie migrated )
7 minutes ago, DavidJPotter said:
C:/My Documents/Chief Version you have
I assume you mean the CA Data folder David?   I had looked there but only found a ssce.ini in a folder called lex..... is that it?
Most all the .ini files I know of are related to spell checking and text details.  I too would be very interested to know if there was a file that was storing my preferences that could be accessed.
Chief saves information in a variety of places.
For a complete list of locations look at preferences. General>Folders will show all the locations data is stored.
To find the location of the .ini files click the button under All Program Paths... and find the location of the Preferences Folder. (usually %appdata%\Roaming\Chief Architect Inc.)
I would use care copying .ini files from one version to another or from one machine to another. It is possible to get in a bad state doing this. Deleting the .ini file should allow defaults to be restored but you can do this within Chief in the preference dialog so I would recommend going that route.
It does make sense to backup the data.
Backup strategy article:
https://www.chiefarchitect.com/support/article/KB-01109/implementing-a-data-backup-strategy.html
Related articles:
https://www.chiefarchitect.com/support/article/KB-00091/backing-up-library-content.html
https://www.chiefarchitect.com/support/article/KB-00654/restoring-the-size-position-of-the-side-windows.html
https://www.chiefarchitect.com/support/article/KB-00775/managing-your-archive-plan-and-layout-files.html
https://www.chiefarchitect.com/support/article/KB-01342/making-a-backup-copy-of-a-chief-architect-program-installer.html
https://www.chiefarchitect.com/support/article/KB-00001/migrating-chief-architect-to-a-new-computer.html
https://www.chiefarchitect.com/support/article/KB-00987/using-the-backup-entire-plan-tool.html
A list of general file management articles:
https://www.chiefarchitect.com/support/category/5/file-management.html
thanks Dan , never knew those were there ....
for those unfamiliar with it , the AppData Folder is in your User Folder ...eg:
C:\Users\YOURUSERNAME\AppData\Roaming\Chief Architect Inc
I have 4 .ini Files in there currently 2 from X9 , from x10 Beta.....
7 minutes ago, Dan_Park said:
%appdata% is a variable name on windows and will take you directly to the folder.
See the following for a more complete list:
https://www.microsoft.com/en-us/wdsi/help/folder-variables
If you are using a MAC use the preferences dialog to figure out where we put things.
Sweet.  Thanks for the information Dan.  I understand the risks involved.  Its nice to know that there actually is a way to store more than one preference set up though...or at least a way to back my settings up.
If defaults (and other settings) can be exported/imported
Then why not preferences ?
It looks like everything is available already ?
Lew
Lew
Never quite understood that one myself , especially since they can be Migrated on an upgrade it seems.....
however Defaults can only be Imported from an existing Drawing (AFAIK) eg your Template Plan , or from you current drawing to your Template Plan to Update it etc , you can't export them like Layer Sets, or Wall Definitions etc.
Mick:
it is these inconsistencies that can drive a Chiefer to drink ;(
Lew
    27469
    THDesign
    THDesign
  • Similar Content
    • By ambrozac
      I don't know if something has changed, or my program didn't migrate correctly.  I've attached a couple of images, hopefully explaining what I'm needing to know.  I am used to learning new tools, but it throws me off, if something is taken away, which I'm not sure about.  Any help would be appreciated, or maybe a link to a helpful video.  I need to know how to get back, that which might have been taken away, so it will work equal to, or better than X9.  You might know this was the first area I looked at, in X10 and I can't get beyond it, until I get this figured out........Thanks!
    • By WendyatArtform
      Here's a whole bunch of videos illustrating some things I've seen folks not understand.  This is by no means some comprehensive training sequence, just something that might help folks understand things and techniques you could adapt to your own style and needs.
      I advanced the attached file a wee bit after finishing up the videos.  My goal was to show minimal adaptation of Chief's oob annotation sets in a way that's closer to real world needs.
      <a href="http://www.screencast.com/t/vicroy80XHQ">Chief X7 lessons</a>
      Chief Plan and Layout.zip
